Hydraulic clutch
Old Jun 27, 2008 | 01:17 AM
Jinxie's Avatar
Jinxie
Default Hydraulic clutch
I am looking for a solution to a stiff clutch. I was looking into a hydraulic clutch setup for my 92 softail. Any feedback? Is this a good idea? Are there some I should stay away from? I noticed Ebay had a few, but how do you know if they are any good....or relieve some of the effort?
&nbsp\\;
Thanks&nbsp\\;
Old Jun 27, 2008 | 07:49 AM
pjb's Avatar
pjb
Default RE: Hydraulic clutch
go with a Mueller power clutch. quicker, easier, cheaper then converting to hydraulic. I was surprised to see that the newer model American Ironhorses with hydraulic clutches were not much, if any, less effort then the cable clutches. Seems like with master cylinder/line pressure reduced effort would have been easy to build in.
Old Jun 27, 2008 | 03:04 PM
dog155's Avatar
dog155
Have you looked into the kits that lessen the pull changing the leverage? White Bros.Easy lite cuts the effort 40% a lot less expensive than hydraulic.
Old Jun 27, 2008 | 08:28 PM
Jinxie's Avatar
Jinxie
Interesting. I thought for sure a hydraulic clutch was the way to go. Just seems a mechanical cable would still be stiffer than the multiplication factor hydraulics can accomplish. I guess for the money an EZ pull kit is worth a try.
Thanks
Old Jun 28, 2008 | 12:08 PM
dog155's Avatar
dog155
1 of my bikes has a Barnett Scorpion clutch with all Red springs (most tension) trying to hold back 180+ lb ft in a RK.The White Bros is just what I was looking for.Go to a dealer and try out the different clutch releases on used bikes to get an idea of the feel
Old Jun 28, 2008 | 09:58 PM
Jinxie's Avatar
Jinxie
I have no idea what it has for a clutch. I know it is stiffer than any other bike Ive owned. The motor is supposed to have 118hp and 134ft lbs torque, so I image there is more clutch there than stock. I will look into your suggestion.
Old Jun 29, 2008 | 11:54 AM
dog155's Avatar
dog155
With that kind of torque I'm sure you have a heavier spring.Just thought of another aid.It is called Dry Lube for your clutch cable.
Old Jun 30, 2008 | 05:46 AM
pjb's Avatar
pjb
tech folks at barnett told me the white bros ez pull does not give you complete clutch travel and they recommended the Mueller type power clutch that changes the ramp angles, but still gives full travel. WWIW if have used the ez pull on a few bikes and it does seem to help, although finding neutral while stopped is harder (probably not getting the full release they talked about). in the future I'd probably try the Mueller type. its about $135 compared to the ez pull at $25, but if the other is better its probably worth the cost difference.
Old Jun 30, 2008 | 05:56 AM
dog155's Avatar
dog155
I can certainly argue that point,since I have 2 bikes both with Barnett Scorpion clutches,and each with the White Bros Easy Lite.Both work better than stock.Fact! the second you pull the lever the clutches release!.What more do you need?
Old Jul 1, 2008 | 05:43 AM
pjb's Avatar
pjb
just telling you what Barnett's tech people told me.
&nbsp\\;
Barnett's teflon lined clutch cables are smooth as silk and help with the pull effort also.
