Push rod seal
Old Jul 28, 2008 | 11:48 AM
Jbeaver's Avatar
Jbeaver
Stage II
Default Push rod seal
&nbsp\\;
What is the step by step procedure for replacing front push rod seal on the front lifter block on a S&amp\\;S 93 inch shovelhead? What is the right way to take off the push rod covers?
Old Jul 28, 2008 | 11:55 AM
JRK5892's Avatar
JRK5892
Default RE: Push rod seal
you ahve to take off the rocker boxes and remove the push rods... it is not somehting to type out... you will need a service manual so you get all the torque specs correct
Old Jul 29, 2008 | 06:39 AM
dog155's Avatar
dog155
I believe you can take the pushrod tube clips off,back the adjusters off enough to get the pushrod off lifter.Readjusting the lifters is easy.Pick up a manual if you do not already have one,you will be glad you did.
Old Jul 29, 2008 | 10:58 AM
Jbeaver's Avatar
Jbeaver
Stage II
&nbsp\\;
&nbsp\\;
&nbsp\\;
&nbsp\\;&nbsp\\; Thanks for the info, last night I took the push tube clip off and raised the bottom tube enough
&nbsp\\;to get the seal back in place, it blew out because there was not enough venting back into the oil tank,took it for a ride and the same old seal held up.
Danny Boy
Shovelhead
Jul 13, 2008 08:52 PM
SloChicken
Jul 3, 2008 05:19 PM
RonnR
Jun 28, 2008 07:24 PM
philpelchat
Jun 24, 2008 09:53 AM
vgfxst05
Jun 16, 2008 05:05 PM
