07 AIH chopper
Old Nov 16, 2009 | 08:29 PM
dmgary's Avatar
dmgary
Default 07 AIH chopper update *******tuned********
So i traded my 07 street glide that was loaded for a 07 texas chopper. got a smoking deal. S&S 117 blah blah blah. I wont bore you with all that cause yes i know its a store room custom. Here is the question has anyone changed the ign and cams in it and if so what did you go to. Thanks in advance.
Old Nov 17, 2009 | 06:35 AM
pjb's Avatar
pjb
what do you call a smoking deal?
you can get new (never titled) AIH bikes for $15k all day long, often less.
Is there a reason you want to change the ignition? There is at least one after market ignition designed specifically for AIH bikes that I know of.
I'm sure you know you have no warranty on your chopper, but they are not hard to work on if you know a little bit about bikes.
your motor has a single cam, there should be no reason to change it.
Old Nov 17, 2009 | 11:35 AM
JRK5892's Avatar
JRK5892
if it is running strong... DO NOT TOUCH IT! once you get it out of tune they will never line back up... trust me i work on them alot! only reason you replace the ignition is if they go bad, as long as it stays cool and dry you will be fine...
Old Nov 17, 2009 | 01:14 PM
pjb's Avatar
pjb
what are you referring to? what doesn't line back up?
I would agree - leave it alone unless you have problems.
if it spits, coughs and sputters when you try to maintain 25-30 mph in town, its probably because the S&S SuperG is jetted way too lean from the factory. They come from the factory with a 29.5 intermediate jet (at least the 111 equiped bikes do). It needs at least a 31 and with the 117 motor I might go with a 33. I also liked the rear mounted kickstand I had on my texas chopper, it got rid of the kickstand drag that made left turns difficult.
Old Nov 18, 2009 | 06:08 PM
dmgary's Avatar
dmgary
Thanks for the inputs. I WILL change the cam so there for i need a ign. Yes i know i dont have a warranty. All i was asking was what ign to put on it. Thats all. im a gear head always looking for more power, yes i work on them as well.
Old Nov 19, 2009 | 06:46 AM
pjb's Avatar
pjb
Still don't understand your reasoning to want to change the cam. I know Big Dog went to smaller cams and SuperE carbs that hurt horsepower from their S&S motors, but AIH never did that with their motors. What cam do you plan to use?
Datyona Twin Tec is the only company I have seen that makes an ignition system specifically for AIH bikes.
TC88A-IH - Special Version for 2004-2007 American IronHorseŽ Motorcycles
American IronHorseŽ motorcycles use a non-adjustable ignition system manufactured in England by Gill. The TC88A-IH is a special version of our TC88A ignition that is compatible with 2004-2007 American IronHorseŽ models. Installation involves cutting off the original equipment 18 terminal AMP connector used with the Gill module and replacing it with a 12 terminal Deustch connector supplied with the TC88A-IH kit. On 2005 and later models, some minor rewiring of the MAP sensor and engine temperature sensor ground connections is required. Please refer to the TC88A-IH Installation Instructions for details.
I don't understand what you hope to gain. What are your goals?
I had a 2004 Texas Chopper for 3 years and now have a 2005 LSC that I've had for 2.5 years. I do all my own work and most of the work for my buddys 04 Texas Chopper.
Just trying to understand what you're after. If its more power thats cool.
Old Nov 19, 2009 | 05:26 PM
dmgary's Avatar
dmgary
Thanks your a great welth of knowledge for me. I do all my own work. Im looking for more power. the heads are going to come off and get port and polised. the bike pings after rejet of the carb.sooooooooooooooooo i want a tuneable ign. What other problems if any have you had with yours? i heard that the trans is junk is this true? Thanks for the help.
Darryl
Old Nov 20, 2009 | 05:45 AM
pjb's Avatar
pjb
not sure if that supposed to be sarcastic or not.
I never have had a problem with pinging after rejetting at least 3 different AIH bikes, what did you change your jetting to?
I'll be the first to admit I don't know much about performance upgrades to the S&S 111, 117 or 124, because I think they all make more power stock then you can effectively use in the Texas Chopper, because the bike just doesn't have the handling characteristics for high speed riding. but thats just me. Somebody once said - "why be in a hurry to get to the accident?"
I've read all the storys about tranny problems but have never witnessed one.
Don't get your speedo wet.
I've replaced various ignition components (used stock replacement parts provided to me under warranty)
Had several speedos replaced (the newer ones are supposed to be much more water resistant, you should be OK)
Replaced an electronic compression release
replace brake pads with Lyndall gold plus pads for longer life and far less wheel dusting.
I think the performance upgrades you are talking about will prove to be an unneccesary, costly mistake, but I wish you luck with it and would be interested in your results. just my opinion, feel free to ignore.
what are the details of your plans and the expected results?
Old Nov 22, 2009 | 06:29 PM
Brown Dog's Avatar
Brown Dog
Hopefully you got a good one. I bought a 07 outlaw brand new and has been the biggest piece of ***t ive ever owned. Chrome flaking off controls and wheels, speedo been replaced, shock bushings replaced at my cost at 500 miles, tranny seals replaced at my cost at same timeand all this happened at 8 months when they went out. I just hope you have better luck than i have and alot of other AIH owners i know.
Old Nov 23, 2009 | 05:29 AM
pjb's Avatar
pjb
Brown Dog - where are you located? what dealer did you buy from?
