Goldwing (brat/Cafe) build
Old May 23, 2011 | 02:48 PM
  #161
JRK5892's Avatar
JRK5892
thanks guys... the biek will get a front fender we are just trying to fab one that will work well with the fork brace and damper... still working on that
Old May 28, 2011 | 01:14 PM
  #162
rmarino14's Avatar
rmarino14
Really cool bike...... great job!
Old Jun 1, 2011 | 11:51 AM
  #163
JRK5892's Avatar
JRK5892
alright! made some updates to the ride
damper installed and cooling fan remote switch added for stop and go traffic
switch
damper:
underside
side profile (clutch side)
side profile brake side
front
fork arm support
mount block on frame
Old Aug 15, 2011 | 06:02 PM
  #164
JRK5892's Avatar
JRK5892
took a cx500 front fender and bobbed it
other than that, changed from the 14mm master to a 5/8 with strait shot braided lines. no more union, removed the kick stand to cut 1/2 inch out of it and weld the foot back on, give the bike a bit more of a lean, pulled the mufflers off so we can slice them open and remove 1/2 the baffles, shorten the muffler a few inches, and re weld it up and coat it again. master lever has been shaved and rounded just waiting to be coated. also pulled the front rotors to recoat them and do somethign a bit diff wiht the coating work. ill get some pics up as we go
well we pressed the baffles out of the mufflers so ddi not have have to cut into the pipe at all! that was nice so jsut had to recoat it! so that should open it up a bit and have it a lil more of a growl to it, kick stand has been cut 1/2 in welded then ground down to get the bike to lean a bit more, new master is coated, lever is coated, rotors are re coated and ready to rock
assembly soon!
well we pressed the baffles out of the mufflers, so that should open it up a bit and have it a lil more of a growl to it, kick stand has been cut 1/2 in welded then ground down to get the bike to lean a bit more, new master is coated, lever is coated, rotors are re coated and ready to rock
assembly soon!
modding the stand
coated
fender lever and master
modding the stand
coated
Old Aug 15, 2011 | 07:11 PM
  #165
Chunk's Avatar
Chunk
http://www.youtube.com/watch?v=9TR6QuOj-Gw
bad music for bad people!
Old Sep 13, 2012 | 06:23 PM
  #166
JonathanCalkins's Avatar
JonathanCalkins
Stage I
How much would you charge to make that bracket for the steering stabilizer? i have been looking for one for my goldwing
Old Sep 16, 2012 | 01:21 PM
  #167
Woffski's Avatar
Woffski
Good work! Will look awesome when all done!!!
Old Sep 17, 2012 | 11:20 AM
  #168
JRK5892's Avatar
JRK5892
it is done... the bike has around 5k on it already... for the damper bracket shoot me a PM i can see if our machinist will turn out another one
JRK5892
Powdercoat & Paint
508
Nov 27, 2015 12:27 AM
lazy ride
Powdercoat & Paint
Mar 16, 2014 10:47 AM
JRK5892
Powdercoat & Paint
11
Mar 8, 2013 07:32 AM
Blade68
May 10, 2012 08:32 AM
JRK5892
Custom Models
42
May 3, 2010 03:53 PM
