Removing Rust off Chrome Parts ?
Old Aug 3, 2017 | 04:03 PM
fatbobbiL's Avatar
fatbobbiL
6th Gear
Unhappy Removing Rust off Chrome Parts ?
What is the best way to remove rust off of chrome parts without doing damage to the chrome piece ???. Thanks
Old Aug 24, 2017 | 07:12 AM
Merlin's Avatar
Merlin
What/where is the rust?
Do you have pics?
__________________
Merlin
Old Aug 24, 2017 | 07:35 AM
Riffraff123's Avatar
Riffraff123
Diet coke, tinfoil ball shiny side out, elbow grease. The diet coke and tinfoil makes aluminum oxide paste, which is a polish and the tin foil isn't hard enough to scratch the remaining chrome. This works for small pits and scratches. If you've got heavy rust, nothing works except rechroming. There's also a hundred different kinds of chrome polish that will work. Simichrome, wadding, Mother's etc.....
Old Aug 24, 2017 | 07:36 AM
wideglideCVO's Avatar
wideglideCVO
000 steel wool works great.
Old Aug 24, 2017 | 07:49 AM
Merlin's Avatar
Merlin
If you need to use steel wool then #0000 would be my 1st choice.
Use #0000 in conjunction with a good lubricity spray. Keep it wet!
A spray bottle with a dawn soap mixture or even Simple Green etc.
Spray and "lightly" wipe with the #0000 and it "should not" scratch.
If it's minor pitting you're cosmetically removing it from the surface.
Always do a small inconspicuous test spot first. Check your results.
Old Aug 24, 2017 | 07:53 AM
Uncle Larry's Avatar
Uncle Larry
Dupont ( Old timers will remember the Dupont Chrome Cleaner #7 ) Chrome Cleaner then A Good Chrome Polish then go back and work on the tougher spots with something a bit more aggressive ( #0000 steel wool as mentioned above )
Old Aug 24, 2017 | 08:00 AM
wideglideCVO
Old Aug 24, 2017 | 08:43 AM
Beaux's Avatar
Beaux
Brillo pad
norseman g
Detailing
Apr 5, 2016 10:12 AM
bobbin87
General Topics/Tech Tips
Jul 28, 2014 08:55 PM
brino
Dec 2, 2010 12:57 AM
Bigpoppa_Junior
11
Feb 10, 2010 08:36 AM
NickyPops
May 21, 2008 12:12 AM
