Need a harder hitter
Old Oct 3, 2022 | 12:06 PM
CaffeineBuzz's Avatar
CaffeineBuzz
Default Need a harder hitter
Use a g8/9 boss white boss cutting pads and Wolfgang uber
ran I to a black paint with a hard as hell clear coat
im open to suggestions on equipment pads or chems
maybe a flex with the same lineup?
Old Oct 3, 2022 | 03:51 PM
Gizmo83's Avatar
Gizmo83
Are those pads foam or microfiber? I get usually way more cut with microfiber than foam. A Flex 3401 is going to have a lot more grunt than the G8/G9 but if you've never used one, they can be a bit of a bear to control until you get the hang of it.
I would
Old Oct 3, 2022 | 09:49 PM
eaglefan1's Avatar
eaglefan1
CB, I did a black caddy this weekend, write up coming soon, and the clear was like concrete. Flex with a MF and UltraCut did a good job, but the owner wanted the best I could get it. Wool pad with Menzerna FG400 did the trick. This took out everything I felt comfortable going after. It was aggresive and I had to follow up with a middle of the road step because what I like to finish with wasnt finishing out what I was looking for.
Wool pad cuts hard and fast, and messy from lint and dust. This worked on this paint with the machine I was using.
What is the issue you are having? Is it worth going after?
Old Oct 4, 2022 | 09:19 AM
CaffeineBuzz
Befores
afters
the first step took some time.....l think a harder hitter would have saved me about an hour of polishing
Old Oct 4, 2022 | 10:08 AM
eaglefan1's Avatar
eaglefan1
FG 400 and/or Cut max. Hell even M105 will knock it out with the right pad.
Old Oct 5, 2022 | 10:39 AM
CaffeineBuzz
I would
foam boss pads
they have 4 that I know of...a white hard, medium orange, softer yellow, and black finishers good pads, also have used Hex Logic....seems to be a great pad as well
Old Oct 5, 2022 | 10:51 AM
eaglefan1's Avatar
eaglefan1
CB, get some Meguiars MF cutting pads. Combine that with their M105 and D300. 2-3 drops of 105 and 1 of D300 and let it eat
Old Oct 5, 2022 | 02:23 PM
CaffeineBuzz
appreciate the input, ain't gonna lie, was hoping you were going to tell me I had to by the Flex
Old Oct 5, 2022 | 07:59 PM
eaglefan1's Avatar
eaglefan1
If your going to do more stuff like this, get the flex. It is a game changer for jobs like this.
Old Oct 7, 2022 | 10:12 AM
CaffeineBuzz
well, if you insist
