ECM no response
Old Jul 31, 2024 | 01:52 PM
FranktheTank37's Avatar
FranktheTank37
Stage II
Default ECM no response
2017 ultra limited I jump started my bike through the starter with a car running and now my bike won't start turn over everything lights up works also BCM code won't turn off . Switched the 2 relays had a 20amp fuse went out replaced that. Could it be the start button itself or maybe the starter harness? Yes I learned the hard way of jumping my bike with a car.
Old Jul 31, 2024 | 02:13 PM
GalvTexGuy's Avatar
GalvTexGuy
Post all the codes you are getting.
Old Jul 31, 2024 | 02:18 PM
CaffeineBuzz's Avatar
CaffeineBuzz
have you tried pulling main fuse and resetting?
Old Jul 31, 2024 | 05:55 PM
FranktheTank37
Stage II
BCM 62271,Rad 61301,
Old Jul 31, 2024 | 06:30 PM
GalvTexGuy's Avatar
GalvTexGuy
Those are:
B2271 - BCM Low Voltage
B1301 - Radio Voltage Low
Those codes are probably from the battery voltage being low.
Were you able to get the bike started with the jump?
How old is the battery?
Old Aug 1, 2024 | 07:44 AM
im's Avatar
im
2017 ultra limited. History of ownership, mileage and any changes from stock unknown.
It was jump started through the starter from a running car for some reason. Battery age and current condition of battery is unknown.
Bike won't start...Unclear of what exactly that means.
"Turn over everything lights up works"...It is not clear if bike does CRANK?
BCM code won't turn off. Codes addressed by another forum member.
Switched the 2 relays and replaced 20amp fuse...What relays? what fuse?
"Could it be the start button itself" ... It is unclear if bike cranks...If bike cranks then button should be OK.
*Clarification would be needed in order to better understand situation.
From a distance it seems like operator should carefully review 4 FOUR ends of battery cables for tight contact and battery should be load tested.
A compromised battery and/or poor connection at any of the four ends of battery cables could easily cause a minimal power but no start situation.
sorensentyler
Apr 19, 2022 09:32 AM
randysavage04
Apr 29, 2018 11:56 AM
zenwarrior
Sep 28, 2007 10:20 AM
Hey Zeus
Aug 13, 2006 04:20 PM
Keith Gleason
General Topics/Tech Tips
Oct 12, 2004 08:44 AM
