ARGH! First paint chip...
Old Apr 27, 2006 | 10:21 PM
tphillips's Avatar
tphillips
Default ARGH! First paint chip...
I've had the bike since July 4th weekend last year and have almost 10K miles on it -- and got the first small chip on the top surface of the front fender. Fortunately, no "ding," just a chip/marring in the paint. Suggestions in fixing this with minimal detection? It is solid black.
TIA
Tod
Old May 4, 2006 | 09:29 AM
whaap's Avatar
whaap
Default RE: ARGH! First paint chip...
I got a good tip years ago from a friend who worked in a body shop. First off, be sure and shake the small container of touch-up paint "extra" well. Then take the end of a tooth pick and just get enough of a little paint ball on the end that when you put the tooth pick in the center of your chip the wet paint will only go over to the edge of the chip and not so much that the paint will flow over good paint. If you think the chip needs more paint, let the first attempt dry first and then later ad a little more.
After a few days of being sure it was totally dry I used a small drimel tool with a buffer wheel and the chip was gone.
Old May 4, 2006 | 07:21 PM
tphillips's Avatar
tphillips
Wow.... thanks. It all makes sense, and now I've got to give it a try. I appreciate the information.
Burstbucker
Apr 24, 2010 01:59 PM
rounder
Mar 20, 2010 05:32 PM
dlsmith82
Ironhead
Jan 20, 2009 06:25 PM
dynasty
Jan 20, 2008 11:23 AM
lowhog
Oct 28, 2007 10:08 AM
