need help w/ bug guts
Old Mar 13, 2011 | 11:23 AM
07 SILVER BULLET's Avatar
07 SILVER BULLET
Default bug removal
the easiest method i've found is to wet the bug infested area, wet a dryer sheet (regular ole clothes dryer sheet), wipe down desired area, then rinse. i use this method on all my automobiles and it works great. after using the dryer sheet water sheets off like a windshield treated with rain-ex. not sure if this method would be safe for denim paint, but i could see in your pic that your bike does not have denim paint.
Old Apr 7, 2011 | 09:07 PM
ebigfish's Avatar
ebigfish
Originally Posted by karjar
mix up a solution in a spray bottle of 50% Hydrogen Peroxide and 50% water. Spray on, let sit for a few minutes, spray again and wipe. works great!
DID IT!
This worked great!
Thanks again.
-fish
Old Apr 7, 2011 | 09:18 PM
mcain49's Avatar
mcain49
Originally Posted by Merlin
Agreed, this is an old bikers trick.
Take a big wet towel (not too wet) and lay it on your batwing.
Let it sit! 10-30 minutes.
The bugs melt right off without the danger of damaging your paint.
I've done it a hundred times.
It's a simple trick and it works!
Tried it and it works well. Great tip - Thanks
Old Apr 7, 2011 | 09:26 PM
marka017's Avatar
marka017
Jesus Christ! Who ties your shoes for you before you go riding? If you can't get the bugs off of it, leave it parked.
Old Apr 8, 2011 | 08:11 PM
ebigfish's Avatar
ebigfish
somebody needs a hug....
Old Apr 8, 2011 | 09:23 PM
T K Glider's Avatar
T K Glider
I use the same ratio but I spray it on when I come home.I then leave the bugs on there til morning.Re apply and wipe them off real easy.
T K
Old Apr 11, 2011 | 07:34 AM
Merlin's Avatar
Merlin
Has anyone tried Bugslide?
Old Apr 11, 2011 | 10:51 AM
TWIN CAM 96's Avatar
TWIN CAM 96
www.purpleslice.com $20.00 for 32oz bottle works very well and no stricking watch the video alot of m/c dealers carry it.
Old Apr 11, 2011 | 02:00 PM
Potato_Potato's Avatar
Potato_Potato
50% Hydrogen Peroxide and 50% water works well - works better while the bugs are still fresh. Hydrogen Peroxide has a limited shelf life - it will last longer if you keep it the opaque bottle it is sold in because sunlight actually changes it to H20. So after a while you will have a mixture of 50% water and 50% water which does not work so good.
Its cheap - I mix up a new batch every season.
RagmanZL
2014-2024 Touring Models
58
Aug 7, 2019 08:38 PM
DarkTrak
Detailing
23
Jun 16, 2014 04:58 PM
mark10
Nov 7, 2012 03:02 PM
scasey
Oct 9, 2011 05:03 PM
customsoftail200
General Topics/Tech Tips
Jan 11, 2007 11:43 PM
