Screaming Eagle Intake
Old Sep 27, 2014 | 02:08 PM
rjo3491's Avatar
rjo3491
Default Screaming Eagle Intake
Hi:
I wanted to add the round air filter cover and now learn that I need to upgrade to the Screaming Eagle intake. That's all fine. Question, will that goof up the EFI or can I make that change without any, "re-mapping". I don't want blue exhaust pipes.
Thanks!!
Jay
Old Sep 27, 2014 | 03:41 PM
jmb79's Avatar
jmb79
The general consensus is that you can install either a high flow air filter or high flow exhaust without a retune, but if you install both you must retune because if you do not, your bike will run too lean.
Old Sep 27, 2014 | 04:25 PM
rjo3491's Avatar
rjo3491
Thanks Jeff. I'm very green here and suspected that this may be an issue. I'd suppose my standard pipes will continue to restrict airflow regardless of what the airbox allows in.
Snowman88
Jun 15, 2019 01:45 PM
FL_Grown87
Apr 27, 2018 11:51 AM
magnum629c
Feb 10, 2014 10:36 PM
dustydog2
Dec 29, 2013 10:33 PM
Ttimos
Jul 11, 2011 06:40 PM
