WTF? Crooked risers???
I've had the best results tightening the clamps first, front two bolts, then the back two. Finally torquing the bottom riser bolts last.
http://www.biltwellinc.com/index.php...t_detail&p=289
They are steel construction with one piece lower, and top clamp. Once I started the bolts into the top tree, through the solid bushing eliminators, into the risers there was absolutely no slop in that combo. Just a mental note I made during final assembly.
I guess if you were running a bushing in the top tree VS the solid bushing eliminators I use there could be a small bit of adjustment to work with here. As far as the top clamp bolts drawing or twisting the lower riser assembly, I dont think thats gonna happen with these risers.
Again, these are just things that I made note of during assembly of my bike. Now I did have to adjust the front end of every bike I have built by loosening the axle pinch bolt/ fender/triple clamp/ Steer stem bolt, and set to preference, then torque carefully.
To the OP, keep us posted with pics, and your findings.
