Internal Wiring problem
Old Oct 11, 2014 | 11:32 AM
blueangel73's Avatar
blueangel73
Not sure how your connector is put together, but if it is like a typical deutcsh connector, this might be helpful.
Old Oct 11, 2014 | 08:43 PM
zZeduardoZz's Avatar
zZeduardoZz
So I am working on making the holes bigger on the bottom of the handlebars, got one done already, just need to go to home depot and buy some eletric tape and pass them through
Old Oct 12, 2014 | 08:55 PM
Suede Blue Man's Avatar
Suede Blue Man
How's this turning out?
Old Oct 12, 2014 | 11:35 PM
zZeduardoZz
Made the bigger holes on the bars, right wiring all done, and left, broke the little plug pulling out the wires, need to go to the dealer and see what I can do, it has been very frustrating and annoying, but a learning experience, I just need the part number for it so I can try and get new left switch control kit
Old Oct 13, 2014 | 11:06 AM
zZeduardoZz
Went to the dealer to try and buy the jae connector, they wanted to charge me $15 bucks for one! Bought it on ebay not 4 of them for 6.95. Just having a little problem putting the throttle together, other than that, its fine...
Old Oct 13, 2014 | 11:30 AM
Suede Blue Man
__it happens, give a shout if you need help.
Old Oct 13, 2014 | 12:47 PM
CACruiserHD's Avatar
CACruiserHD
I ended up cutting mine and soldering. It would have been literally impossible fitting the connectors thru my bars still intact & I don't want to mess with taking the fittings apart and back together. It then becomes a matter of where is the weak point (a solder or where I yanked on fittings, removed pins, etc and put it back) . My solder is solid though. I can solder a wire and pull with all my might and the wire snaps before the solder does.
clap
Apr 5, 2017 08:07 PM
RHillbilly
Oct 31, 2009 07:59 AM
14U24ME
Mar 22, 2009 09:32 AM
bajabob
Apr 23, 2006 09:52 PM
HDF Tech
Jun 25, 2005 06:46 PM
