2002 FXD Electrical headache
Old Oct 18, 2014 | 11:26 AM
andrewppoole's Avatar
andrewppoole
Default 2002 FXD Electrical headache
Recently just installed a new starter and now the headlights flicker, speedo is bouncing to zero and the bike is sputtering all at the same time. Someone please help!! Pulling my hair out lol
Old Oct 18, 2014 | 11:39 AM
skinman13's Avatar
skinman13
According to my wiring diagram and how my '01 is wired, the battery positive goes straight to the starter and then to the main circuit breaker and ignition switch from there...go back and check your wiring and connections...you probably have a loose or damaged connection...the starter connections you made are a good place to begin looking.
Old Oct 18, 2014 | 11:40 AM
nevil's Avatar
nevil
You didn't say what you tried so far (except for pulling out your hair), but go to the simple stuff first. I would go back to the starter and check over every wire and connection involved in that job. Then look at the battery connections, and don't forget the ground.
Old Oct 18, 2014 | 12:04 PM
andrewppoole
Yeah sorry about the lack of details on the troubleshooting end... I checked the battery terminals (were a tight) and there didn't seem to be a pinched wire anywhere either... I'll unplug/ replug in the starter and will see of that might help.
scarecrow 82
Electrical/Lighting/Alarm
Mar 19, 2021 05:47 PM
dyydjbb
Oct 1, 2016 03:11 PM
1unclejojo
Shovelhead
Sep 6, 2012 07:52 PM
toolbox
Mar 8, 2009 08:43 AM
saweet96
Jul 15, 2006 03:20 PM
