49mm Fork preload adjusters?
Old Nov 1, 2014 | 12:35 PM
2500hdon37s's Avatar
2500hdon37s
Default 49mm Fork preload adjusters?
I see a few places make them, and are a supposed drop in. I added some preload to the rear and that's made a noticeable difference in handling for the better, so I'd like to do the same to the front. I'm not the average rider being a pretty light guy, so I was wondering is it really worth the $100+ for about an inch worth of front preload adjustment?
Also who makes the best and easiest to adjust ones? I like the RSD's with just over an inch in adjustment, but I'm a little unsure of how they work or how easy they are to install. I'm not afraid to open up the forks but will I need fork oil or anything?
Old Nov 1, 2014 | 12:43 PM
Mr Bentwrench's Avatar
Mr Bentwrench
Do you really need them? What do you currently measure for static sag and rider sag? You know once installed and adjusted they are pretty much a set and forget deal with cosmetics being the only residual benefit after that.
Edit: For the $100, look as aftermarket springs first.
Old Nov 1, 2014 | 01:13 PM
sharkey's Avatar
sharkey
The fully adjustable suspension on my FXDXT included pre-load on the front forks and I used it whenever riding conditions could be improved by a change (as well as the other settings that were available) A lot depends on your riding style...slow, relaxed cruising is not nearly as demanding on the suspension as more aggressive riding on a high torque/high HP bike for sure. I've sold the FXDXT and now tour on an FXDF; it could use some pre-load as I bottomed out the front end on a panic stop once or twice (deer) and the back shocks aren't even so-so; but it's hard to find traditional looking shocks with re-bound control. Having said all that, I'll definitely be going with adjustable pre-load and maybe heavier old when the bike is down this winter for mods; it seems a cheap add-on that will help with front end dive and ride. But; the rear shocks AND the tires are all part of the same handling package...
Old Nov 1, 2014 | 02:26 PM
EricInNCa's Avatar
EricInNCa
I think the install is the same no matter what brand you get (Speed Merchant, RSD, etc.) I have the RSD adjusters. Install is fairly simple and no oil change, etc. is needed at the time of install. Once installed, you can adjust the preload with an allen wrench on the RSD units. Just follow the instructions and you should be fine. Btw: There was some confusion about the pricing in some other postings. The price listed is for BOTH units.
Old Nov 1, 2014 | 08:07 PM
2500hdon37s
Do I really NEED them? no, but I dont need a lot of things I have. But I feel the adjustable preload is nice to have as I'm constantly fiddling with the rear pre load a lot depending on if I'm just commuting to work over the week, long ride, or a more aggressive ride with my cousin on his CBR.
I'm also considering progressive springs, could be a simple one stop shop while installing if I do both...
Old Nov 1, 2014 | 08:09 PM
2500hdon37s
Looks like I'll be picking up the RSD's most likely, and I saw those few posts about the RSD price of "each" thing lol thanks for some positive confirmation!
I guess I was a little worried about install as I hate messing with front forks much on a bike and dont have a shop manual for my bike yet!
Old Nov 1, 2014 | 09:42 PM
monster715's Avatar
monster715
Just make sure you loosen the top pinch bolt when you remove the cap and reinstall the adjuster. Careful trying to tighten the rsd's they gouge real easy. I hand tightened mine since the pinch bolt locks it in place
Old Nov 2, 2014 | 09:55 PM
fatmanontwowheels's Avatar
fatmanontwowheels
I have the Speed Merchants. While maybe not as pleasing to the eye as the RSD to some ( they are to me ), I like the fact that the adjustment stem has grooves machined in them which makes adjustments almost idiot proof.
streetfighter06
Jan 20, 2025 03:55 PM
nhbubba
2014-2024 Touring Models
Apr 26, 2018 09:36 AM
JP7
Apr 16, 2018 11:47 PM
johnnyglass
Mar 1, 2016 04:32 PM
anubisss
Sep 20, 2007 01:25 PM
