Fat Bob Seat Removal
Old Nov 18, 2014 | 09:38 PM
OneGearhead's Avatar
OneGearhead
Originally Posted by maddghost
Hey FNG welcome to HDF. These guys have it wrong. you don't want to remove the strap just the seat right? Once that rear bolt is off slide the strap as far as you can towards the tank, then grab the rear of the seat and pull back until the tab slides out from under the tank. Then angle the seat away from the tank and slide the strap back as you push the seat forward. duh duh done!
You could avoid all this ribbing if you RTFM. First you will need to buy one though!
This! You don't need to remove the strap.
By the way, welcome!
Old Nov 19, 2014 | 02:06 AM
wastedranger's Avatar
wastedranger
Strap does not have to come off to remove seat. Makes it absolutely miserable to remove it though. So once seat is off get rid of the strap. Only reason I've ever found use for it was to slide gloves or ball cap under. It's called a grab strap for some reason. Maybe its so you can ride your bike one handed like a rodeo bull.
Old Nov 19, 2014 | 02:22 AM
ynots's Avatar
ynots
My .02˘
#1 Take knife and cut strap
#2 Throw strap in garbage
Old Nov 19, 2014 | 05:19 AM
adm's Avatar
adm
It's about a 30 second job on mine even with the strap. Remove rear bolt, pull seat backwards to disengage the tab that sits under the fuel tank, then twist the seat through 90 degrees and slide it out from under the strap. Be careful not to scratch the paint on the rear fender though.
Old Nov 19, 2014 | 08:27 AM
Rubline's Avatar
Rubline
Nothing easy about Harleys, huh guys?
Old Apr 30, 2015 | 12:22 AM
romac's Avatar
romac
What a stupid Design.....Tried to remove my seat and thought what were they thinking?
Old Dec 3, 2021 | 09:33 AM
SJMathisen's Avatar
SJMathisen
hey fng welcome to hdf. These guys have it wrong. You don't want to remove the strap just the seat right? Once that rear bolt is off slide the strap as far as you can towards the tank, then grab the rear of the seat and pull back until the tab slides out from under the tank. Then angle the seat away from the tank and slide the strap back as you push the seat forward. Duh duh done!
You could avoid all this ribbing if you rtfm. First you will need to buy one though!
yup...what he said
Old Jan 11, 2022 | 01:13 PM
Czracer's Avatar
Czracer
Default Thanks for info
Originally Posted by ynots
My .02˘
Thanks for the info , Dealer I bought my bike had a winter charger harness installed to battery for trickle charger and once bike was delivered to my house didn't see the harness so have a feeling it was removed , and will have to remove the seat to install a new one
spikesworld
Mar 6, 2017 05:02 PM
sixty-niner
Dyna Parts
16
Nov 10, 2014 06:04 PM
sanlyn
Dyna Parts
Mar 24, 2010 08:54 PM
flyingfez
Oct 13, 2008 02:22 PM
Scooter Wench
Mar 31, 2008 11:37 AM
