Baker Compensator in Testing
Old Dec 3, 2014 | 08:21 PM
HD Bobber's Avatar
HD Bobber
I found pictures of the part numbers when I bought me SE Comp along with the glue that came with it......just for reference for anyone that may need it.
Old Dec 4, 2014 | 07:08 AM
blueangel73's Avatar
blueangel73
As I am learning more and more about my bike and how everything works, drivetrains are not my specailty, I know every little about how it in fact. Can someone enlighten me as to what the compensator is, does and how I would know when it is time to change it? Thanks
Old Dec 4, 2014 | 07:16 AM
Warp Factor's Avatar
Warp Factor
The compensator basically puts some "spring" between the engine and the transmission.
Old Dec 4, 2014 | 07:29 AM
soft 02's Avatar
soft 02
Subscribed.
Old Dec 5, 2014 | 09:00 AM
corliss@bakerdrivetrain.com's Avatar
Originally Posted by HD Pilot
Sweet! I know you probably do not want to reveal too many details but any tidbits are appreciated... OK for bigger builds? Any fluid type requirements? Any special tools other than the primary locking bar, and torque wrench(s)?
What I can tell you is that it is very similar to the 5 speed style compensator if your familiar with those. No special tools, and as always we recommend Spectro or Redline primary fluid.
Old Dec 5, 2014 | 05:57 PM
filthpig's Avatar
filthpig
hey mark @baker drivetrain
hello sir,
Is there any consideration of making this compensator in a 30 tooth variety?
I have moved onto using the Evolution Industries 30 tooth solid sprocket.
Converted over to chain final drive 24/53. The 34 tooth motor sprocket did not give the gearing justice and I did not want to go with a bigger final drive sprocket.
At any rate if this new compensator could be offered with less teeth than stock, it would be my next purchase!!
thanks,
filth
Old Dec 10, 2014 | 10:23 PM
Sharpie's Avatar
Sharpie
I'll Hang around and listen to this thread
Old Dec 10, 2014 | 10:32 PM
HD Bobber's Avatar
HD Bobber
It's been pretty quiet for a while, but I'm sure it will come alive once someone gets their hands on the new comp.
Old Dec 11, 2014 | 08:01 AM
HD Pilot's Avatar
HD Pilot
Can anybody post up a Service Manual picture of the 5 speed compensator?
Old Dec 11, 2014 | 08:11 AM
HD Bobber's Avatar
HD Bobber
The splines are totally different than our and the crank is shorter on the 5 speeds. Here is a pic:
