Turn signal mod throwing codes.
Old Apr 4, 2015 | 02:27 PM
KxTRT's Avatar
KxTRT
6th Gear
so I am starting to regret joing this dang site...I cant get PM's yet, and I cant see the pictures you posted of the headlight...how do you like it? i am thinking about ditching the light bar on my 2005 Road King and adding that headlight. Any thoughts on it after having it for a few months now?
Old Apr 5, 2015 | 04:37 AM
Davdoodles's Avatar
Davdoodles
Default Just reset the TSSM
Adding load resistors etc is, these days, usually unnecessary.
Like the OP, I swapped my rear sigs for LEDs and got the error and "fast flash" thing (2011 FXDB).
Essentially, this is just a function built into the TSSM (Turn Signal Security Module) that alerts the rider to a problem in the turn signal system.
In medieval days (like 1970s-80s) signals would blink faster if one bulb was blown, due to the lower resistance across an old-school semi-mechanical blinker unit that relied on heat build up to turn it on-off-on-off.
In those old systems, it was necessary to add resistors (aka load equalizers) or get a different blinker unit.
Nowdays (even prior to canbus) blinking is usually done electronically via the TSSM, but is designed to mimic the old-school system for safety I guess. Stuff around with the system, it'll blink fast to warn you of potential error...
Here's what I did:
RESET THE TSSM:
- Pull the front brake lever and hold it on.
- Turn ignition ON. Brake light should now be on.
- Push the left signal button, then push the right signal button immediately.
- This will reset the TSSM.
That's it. Worked first time, and and blink rate has been normal ever since.
I don't know if the 2007 is the same TSSM as mine (2011) but it probably is...
I hope that helps.
cowboybob56
Electrical/Lighting/Alarm
Apr 30, 2018 07:20 AM
deadlydeacon
May 24, 2016 12:34 PM
CLROB3
Aug 31, 2010 10:48 AM
RKTonyC
Sep 27, 2009 05:28 PM
RKTonyC
May 27, 2009 08:11 PM
