First time wrench's guide to tools, 5k service, and cam change
Old Mar 13, 2015 | 06:22 AM
  #111
CanonSterVA's Avatar
CanonSterVA
Great details...
Subscribed to watch and read again!
Old Mar 13, 2015 | 07:33 AM
  #112
robbyville's Avatar
robbyville
Good luck. Have you chosen a cam yet? You're not that far from me should you decide you need an extra hand when it comes time to do the work!
Old Jan 15, 2018 | 03:58 PM
  #113
Sethcat's Avatar
Sethcat
Hey guys, great thread, Robbyville! Thanks for putting it together. I am about to get started on my Andrews 57H cam swap as soon as I figure out which other parts/ tools I need get them ordered.
Not sure if I missed this in your thread but maybe you or somebody else can answer. You went with the S&S Quickee adjustable pushrods but you replaced the lifters as well. From what I have read, the difference between the Quickees and the S&S adjustables are that for the adjustables are a bit stronger but you have to remove the tappet cover to install them. Is there a reason you still went with the quickees?
Thanks!
Old Mar 26, 2018 | 10:22 AM
  #114
robbyville's Avatar
robbyville
Thanks!
So sorry for the delayed reply and I'm sure you've already completed your work... I went with the quickees, purely for future ability to not have to remove the tappet covers. This worked well for me since I did most of my engine work in piecemeal fashion doing the heads, then later new cylinders, etc.
Hope this helps and ride safe!
Old Mar 26, 2018 | 09:36 PM
  #115
Pylot7's Avatar
Pylot7
Hey Robbyville this been a great write up.
I have been doing the cam install and exhaust upgrade to my Dyna over the winter.
I got stopped out at installing the adjustable pushrods because I was trying to use the stock pr covers and there is simply not enough room for me to bend over and work the threads. So I have a set of pr covers coming that are like the S&S covers, a bit shorter with a longer keeper to give easy access to the adjusting of the prs.
Its a great experience to do your own. I also found everything took much longer that I thought it would but no harm in that. I have also scored some great new tools in the process of saving money
I keep looking forward to that quick mount of the exhaust and getting it buttoned up so I can flash it and go for a ride.
Thanks again for the great writeup.
Old Mar 27, 2018 | 09:18 AM
  #116
robbyville's Avatar
robbyville
Great to hear, enjoy and ride safe!
Joe_G
Dec 1, 2020 02:31 PM
BobFLHT2002
Engine Mechanical Topics
Jun 7, 2018 08:27 AM
atrain68
Jul 16, 2014 07:21 PM
atrain68
Apr 4, 2012 08:08 AM
lt1tyrell
Exhaust System Topics
Aug 26, 2011 11:56 PM
