Andrews Conversion Cams Checklist
Old Jun 5, 2018 | 09:11 PM
BobFLHT2002's Avatar
BobFLHT2002
Default Andrews Conversion Cams Checklist
2002 FLHT, TC88, stage 1 intake and exhaust, 22,000 miles. I'm gathering everything I need to install Andrews Conversion 21N Cams. I just wanted to know if I'm missing anything, like specialty tools, or if I should do anything else while I'm in there.
Here's what I have:
  • 21N cams
  • newer cam support plate
  • newer oil pump
  • newer primary and secondary drive chains
  • newer primary and secondary cam tensioner
  • Rockouts rocker shaft inserts
    • I'm going to take the tank off and reuse my pushrods
    • I figured I might as well do this upgrade while I'm in there
  • James Gasket Cam Change Kit (JGI-25244-99-K)
  • new inner cam bearings
Specialty tools I have:
  • a two sided cam/crank locking tool that should work on tc88s and tc96s
  • inner cam bearing installer/puller
I'm about to order:
  • The two newer cam drive sprockets
I know I'll need some screws and a spacer, which I think I'll get from my local dealer.
The bike has 22,000 miles, but is 16 years old. I haven't planned on changing lifters. Good idea/Bad idea?
Will I need any other specialty tools, maybe for working with the pushrods and lifters?
Anything else I should do while in there? That isn't expensive...
This is a first time project for me, I have a service manual for my bike and should have access to a service manual for a newer twin cam 96 when the time comes. I have a lift table and all the normal mechanics tools.
Thanks for the help.
Old Jun 5, 2018 | 09:20 PM
marcodarq's Avatar
marcodarq
Replace your lifters, i suggest using the ones from S&S or Jim's. I also use the oil pump alignment screws, which are the same tool as the old evo tappet block alignment screws. A quality 3/8's and 1/4" drive torque wrench should also be included in the list.
m
Old Jun 5, 2018 | 10:22 PM
VTME13's Avatar
VTME13
I also did the Andrews 21N conversion and inner bearings. You'll love it. I pulled the tank and reused my stock push rods and lifters (19k miles, no scoring or abnormal wear patterns).
Found this blog post while researching the swap... has a pretty comprehensive parts list and a good write up:
http://www.bikernet.com/pages/Andrew...Cam_Plate.aspx
I used this as a guide to order stuff. Some of the part numbers are back level because the write up was done in 2010, but you'll see that when you look'm up to order.
I have a 0.030" stock bore head gasket for sale in the classifieds if you're interested in bumping the compression a touch since you'll be right there.
Last edited by VTME13; Jun 5, 2018 at 10:23 PM. Reason: Saw that you have the inner bearing tools already.
Old Jun 5, 2018 | 10:51 PM
bad tappets's Avatar
bad tappets
Sounds like you have everything.
+1 on the oil pump alignment screws.
Also, you might think about changing the breathers to the new style, since you have the rocker boxes open. There pretty cheap and easy to install. I love the 21N cam.
Old Jun 6, 2018 | 06:51 AM
ROCKOUT Rocker Products
Sponsor
A note on the breathers...
If you change from old to new style breathers you MUST use the shorter screws designed for them. If you buy the kit they are included. Using the old longer screws with the new breathers can crack the head
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old Jun 6, 2018 | 06:19 PM
DonnieM's Avatar
DonnieM
Do the inner cam bearings as suggested. did a TW 21 cam on my 06 Ultra. Tuned, you wont be dissappointed
Old Jun 6, 2018 | 09:53 PM
BobFLHT2002
Thanks for the info. I'll order the alignment screws. The breather is inexpensive, is it a better design than what is in my '02? It is hard to keep track of what HD makes better over the years and what they just make cheaper.
Now I'm in the paralysis by analysis stage of looking at different lifters. I don't need the best, I just need good enough for a 16 year old, 88in bike. This is a budget project.
Old Jun 7, 2018 | 12:36 AM
VTME13's Avatar
VTME13
Wouldn't stress about lifters too much. The 21 cam doesn't have ridiculous ramp rates or super high lift, and you won't be turning whacky high rpms.
A new set of stock lifters is probably good enough, IMO.
Old Jun 7, 2018 | 06:38 AM
Sponsor
I run Hylift Johnson lifters from WFOLarry,,, http://www.larrysmotorcyclemachine.com/lifters.html
Old Jun 7, 2018 | 08:27 AM
Screamin beagle's Avatar
Screamin beagle
A set of s and s standards is about 120 bucks...best piece of mind you can buy for your bike. 100 percent of the time is when you should scrap those junk stock lifters, ask anybody who's had one fail and wipe out their motor.
internet troll
Jun 3, 2019 01:47 AM
Hogpro
Nov 6, 2015 02:33 PM
skully1200
Exhaust System Topics
Nov 26, 2011 04:30 PM
Biker Bob
May 27, 2011 09:02 AM
omgtkk
EVO
Aug 28, 2010 02:57 AM
