rev limiter...
Old Apr 17, 2007 | 07:15 PM
bigmo_dynasb's Avatar
bigmo_dynasb
Default rev limiter...
i have a 06 street bob...
i have purchased the TFI, Arlen Ness Big Sucker..and am looking at gettin the staggered short shots..
i have not had the download..
but i do want to be able to bump up my revs..
is the download the only way or is there a add on i can purchase?
thanks
Old Apr 17, 2007 | 07:18 PM
Shrug's Avatar
Shrug
Default RE: rev limiter...
The PCIII can do it. CTRL/F3, I think. My dyno tuner bumped mine up to 6200. I'm sure the TFI can too.
Old Apr 17, 2007 | 08:14 PM
dailydriver's Avatar
dailydriver
Bigmo
are you done with your engine mods? If so just get the Stage 1 chip burn..I've got the same set-up Big sucker and V&H shorties. .Stage 1 did me fine..pulled the plugs after 100 miles and they're perfect...I know alot of guys swear by the PCIII and I run one on my 05 bagger..But I wasn't ready to give up the closed loop feature of my Bobber...PCIII has O2 sensor eliminators that feed a false reading to your ECM.
If you're going to keep going with your engine mods Get a ThunderMax w/ auto tune Its' pricey but its 100% closed loop and will adjust to new mods and no dealership tune time is needed...
Old Apr 17, 2007 | 09:14 PM
bigmo_dynasb
no i am done after these mods...dont forsee any engine mods at least for a few years...
Old Apr 18, 2007 | 02:15 PM
bigmo_dynasb
so is the download the only way to get the revs moved? without having to go with a PCIII or sert or any of the other expensive tuners?
Old Apr 18, 2007 | 04:48 PM
Macs06WG's Avatar
Macs06WG
i didnt need to up my rev limiter with just exhaust and air kit mine made max hp before the stock rev
Old Apr 19, 2007 | 08:48 PM
dailydriver
Only way to up the rev limit that I know...And, probably the cheapest bang for your buck...I think you'll be happy with the combo you picked...Later
TheDarkRider
Feb 17, 2015 07:57 PM
havona888
Jan 10, 2010 07:25 PM
Low_Wider
Sep 21, 2007 07:34 AM
Parrothead
Jun 21, 2007 01:07 PM
MarkM
Jan 3, 2007 06:41 PM
