cam problem?
Old Jan 18, 2015 | 05:28 PM
allsop's Avatar
allsop
Default cam problem?
Look at my exhaust cam in pic,
my Dyna 07' FXDi has only ~5k miles, all stock, and the exhaust lobes show witness from the rollers of the hydraulic lifters.
This bike only carries 3 Qts of oil, any thoughts of why this is? Oil pressure? Lack of oil?
I discovered this while changing cam bearings, and will also be swapping cams to a set of Andrew's with quickee pushrods. Crank runout was less than .003" also.
Old Jan 18, 2015 | 07:39 PM
rsking45's Avatar
rsking45
I would post that in the tech section. There is a good number of builders , Hillside to name one that will be able to help you out with this
Old Jan 18, 2015 | 09:07 PM
vdop's Avatar
vdop
Normal
Old Jan 24, 2015 | 12:23 PM
amfhd's Avatar
amfhd
The cam in the back of the photo is normal, the front one is not. Maybe a local mechanic will help you out?
allsop
Engine Mechanical Topics
Jan 19, 2015 01:55 PM
djack
Oct 15, 2011 12:40 PM
parakiller
Mar 10, 2011 04:15 PM
blair
Mar 6, 2011 09:32 AM
harleynt
Exhaust System Topics
Sep 11, 2008 07:54 PM
