Mag wheel conversion
Old Jan 25, 2015 | 04:48 AM
Deathbat9's Avatar
Deathbat9
Default Mag wheel conversion
Ok, I have a 2001 Super Glide FXD with mag wheels. I also have an 06 Streetbob with spoke wheels. I was wondering if it was possible to flip these wheels as i am keeping the street bob and going to be selling the super glide. I believe the difference would be the spacers on the wheels didnt know if perhaps i could just perform a quick flip flop. Thanks
Old Jan 25, 2015 | 06:01 AM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
You'll need to switch the bearings as well (2001 3/4" vs 2006 1")
Old Jan 25, 2015 | 06:50 AM
Campy Roadie's Avatar
Campy Roadie
So if he puts 3/4" bearings and axle sleeves on the 2006 mags they'll work on his 2001? (providing he uses the 2001 3/4" wheel spacers)?
Old Jan 25, 2015 | 08:45 AM
Papple's Avatar
Papple
Default Wheel Swap........
I believe HD went to a wider rear wheel & tire on the 2006 up bikes so the 06 wheel won't fit in the 02 Rear Fender.
Ride Safe,
P
Old Jan 25, 2015 | 09:05 AM
FXD2003Rider
Not sure if they will fit with the spacers. Hubs for 2001 and 2006 models do have different p/ns.
According to some parts diagrams I checked at http://www.cyclecityltd.com MoCo switched from 3/4" (p/n 9267 52mm OD, 3/4" ID) to 1" (p/n 9247 52mm OD, 1" ID) bearings on '06 and later Dyna models.
Old Jan 25, 2015 | 10:18 AM
Nikolaiownz's Avatar
Nikolaiownz
Dude.. just pull it apart and see if it will fit
Old Jan 25, 2015 | 11:10 AM
U-234's Avatar
U-234
Axle Info: Dyna
2000-03 Dyna have ž” front axle, 2004-07 Dyna have 1” front axle (except 2004-05 FXDWG), 2000-05 Dyna have 3/4” rear axle, 2006-07 Dyna have 1” rear axle. 2000-05 FXDWG have ž” front and rear axles, 2006-07 FXDWG have 1” front and rear axles. All Dyna have 25mm axles from 2008+.
Info from J&P Cycles Catalog.
Old Jan 25, 2015 | 11:51 AM
07bobber's Avatar
07bobber
You wont be able to put the street bob wheels on the 01 fxd. The front hub is too wide for the narrow forks. And the rim for the rear is too wide as well
Old Jan 25, 2015 | 08:21 PM
Deathbat9's Avatar
Deathbat9
Thank you to everyone for your help and the info.
Rad Dog
Apr 17, 2014 11:41 AM
ldfry001
Mar 24, 2013 07:02 PM
JohnCA58
Jul 27, 2009 08:03 PM
richmac64
Sep 19, 2007 09:20 AM
mini9r
Apr 5, 2006 08:40 PM
