This bike has no mileage on to speak of and has been stored 20 years. I am interested in buying it. I assume fuel and oill lines, tires, and maybe cables need to be replaced. Anything else I should be concerned about? Any advice appreciated.
There are some pretty good threads on dehibernating a long stored bike here. Fuel is usually the first and biggest issue with the condition of the carb (crud) and tank (rust). Change all the oils and throw a battery on it and fire it up. Ride wise it's a brake fluid flush and getting the old hard tires to hold air.
Trick is concentrate on first getting it to start and run and then worthy enough to just ride around the block. The other priorities will become more obvious then.
The carb will (most likely) have to be rebuilt. I have some experience re-building 40mm Mikuni carbs...which is probably what you have. Let me know if you have any questions. K&L makes a good and inexpensive rebuild kit if needed.
You might want to squirt a little Marvel Mystery oil into the cylinders and turn the motor over slowly by hand with the back wheel and plugs out before using the starter just to make sure it free...
Yeah forgot to mention that. Marvel is fine. I use 20w. Trick is to get it all loose and freewheeling and the rings floating again before putting it under compression. Once I even towed a locked up car slowly around the block in 2nd gear to get everything moving again. Saved me a rebuild. You get the idea.
Personally unless that bike is priced accordingly (low), I'd pass on it. Regardless of mileage, a used bike that's gone unused for 20 years is a huge negative IMO. You may have to replace a lot of engine gaskets. I wouldn't be surprised if trans seals need to be replaced as well. If it starts leaking anywhere once you start riding it, I'd just replace them all.
I bought a 93 FXR last March out of Indiana and rode it home to CA in April. When I picked it up, it only had a slight rear base cylinder gasket leak. Without exaggeration, 5 days and 2400 miles later, it was leaking oil from anywhere that it could leak. I didn't care because I was planning to take it apart anyway to install the go-fast parts.
That year EVO also has the dreaded INA cam bearing that's certain to fail at some point. I've personally seen them fail at as few as 14k miles, or last nearly 50k miles. Mine failed on the FXR at about 45k miles. The plus side of changing that bearing to a Torrington brand bearing, is that it gives you the opportunity to upgrade the cam while you're in there. If you don't catch it in time, it can destroy the engine beyond repairs.
20 year old tires are only good for rolling it around and a couple of quick shake down rides (around the block). Plus they will likely have some bad flat spots.
Besides that, for the right price it could be a fun project.
