Starting engine causes signals to blink fast.
Old Feb 10, 2015 | 08:35 PM
sdeck86's Avatar
sdeck86
Default Starting engine causes signals to blink fast.
I've been trying to diagnose a problem I've been having for a couple of months now with no luck. I installed H-D lighting everywhere and the rear LEDs have been giving me issues.
Sometimes after riding for a long time with normal signal functionality, the console signals will begin blinking fast. When turning the bike off and restarting it, they function normally again.
I've also noticed that sometimes the rear signals function fine until I start the engine, at which point the console signals begin blinking quickly and the rear signals don't anymore. Sometimes only one signal stops working, while the other continues working.
I'm at a loss with these. Does anyone have some insight for me?
Old Feb 10, 2015 | 10:03 PM
maddghost's Avatar
maddghost
if you have a load of led's on there it sounds like all you may need is a load equalizer, or double check your wiring.
Old Feb 22, 2015 | 04:52 AM
sdeck86's Avatar
sdeck86
Default Sorted
Finally got this sorted out. I took it into Harley yesterday morning and had a return call 20 minutes later. They never really gave me an exact description of my error codes, other than to say the BCM was having issues communicating with my rear signals. They tried installing a rear load equalizer, but it caused even more signal dysfunction. Ultimately, they decided there is a compatibility issue with newer bikes and LEDs.
We decided to try tricking the BCM into functioning normally by installing stock incandescent lights on my forks. I've read about people doing this to correct signal problems. Today my girlfriend found several photos of LED/incandescent combos that are almost my exact setup. Two hours later my error codes were gone and all SIX signals worked perfectly. Parker, the SLC Harley manager told me he "puts out the fires" and charged me absolutely nothing for their work (which included fork mount parts).
I had issues with these signals for months and did a good amount of research to try and solve the problem. Once again, the Harley dealership came through and my bike is at 100% again. Hopefully, this may be helpful for anyone else having LED problems.
Old Jun 29, 2015 | 02:52 AM
sdeck86's Avatar
sdeck86
UPDATE. I've enrolled in MMI and been in motorcycle mechanics for about a month. Since then I've decided am the only one who is going to work on my bike from here on out. This last week I sorted my signal issues. The stock connector socket for the front signals are three-wired, and the LED mirrors I installed are two-wired, with an included Y-harness that turns 2 into two 3 connectors (one for the stock signal, and one for the stock connection). This is what has caused my LED issues from day one. As long as the wiring matches up with the BCM configuration there are no issues. I am selling my auxiliary mirrors after installing the aftermarket Harley bullet signals and having no blinking issues. I COULD keep the LED mirrors except that I'm over them and don't want four front signals/lights besides my daymaker.
vtchopperdude
Oct 27, 2018 06:44 AM
sdeck86
General Topics/Tech Tips
Mar 12, 2016 09:38 PM
sdeck86
Electrical/Lighting/Alarm
Jun 29, 2015 03:00 AM
sdeck86
Jun 29, 2015 02:51 AM
sdeck86
Feb 22, 2015 04:53 AM
