Tips on switching bars
Old Feb 23, 2015 | 01:31 PM
Bobbystreetz's Avatar
Bobbystreetz
Stage IV
Default Tips on switching bars
I'm not a mechanic what so ever. But I am pretty good with my hands and not an idiot lol. I ordered the rs 12" z bars and putting them on my 2014 street bob. I currently have the stock 10" mini apes installed. I'm Basically just wondering if anyone had any tips, steps, or problems I might encounter. Thanks!!
Old Feb 23, 2015 | 01:45 PM
STRES's Avatar
STRES
search is your friend...
this one is pretty good.
https://www.hdforums.com/forum/dyna-...odel-bike.html
if you have any issues post em and we will do our best to help you out.
it is fairly straight forward though.
Old Feb 23, 2015 | 03:07 PM
ghicks80's Avatar
ghicks80
Yeah it's not bad at all really and going to 12 you don't have to buy any cables stock will reach easily. The worst part I would imagine is running the internal wires back in the bars which I avoided by going old school cool external lol and even that won't be difficult.
Old Feb 23, 2015 | 06:28 PM
tharp92's Avatar
tharp92
3rd Gear
The install is pretty simple... you just have to be patient. I used some small wire that I fed through the bars and taped it to the housing wires and slowly pulled them through.
Old Feb 23, 2015 | 09:04 PM
robbyville's Avatar
robbyville
Thanks to Stres for posting that link. It was my first time doing that, 2014's are much easier, don't need to remove tank and connectors go right through the bars (just make sure to protect them), find some type of leader to put through the bars and then attach the lead with electrical tape to the wire. Some string with a small weight would work well to get through the bars (tip, get the leads done before you mount the bars lol!).
Tool wise it's pretty basic, do you have torque wrenches and service manual?
Old Feb 23, 2015 | 09:17 PM
BigDogIdaho's Avatar
BigDogIdaho
You can also use twine and a shop vac. Put the twine in the bar, and use your vac to pull it through. Tie it on your wires and pull.
Old Feb 23, 2015 | 09:55 PM
STRES's Avatar
STRES
this is a good way, you can use different variations of this method. remember with a 2014 you SHOULD NOT need to de-pin/ re-pin any connectors YMMV
Old Feb 24, 2015 | 10:54 AM
Sean McGuinness's Avatar
Sean McGuinness
I just did mine... as these guys are saying, no real tools needed. When I snaked the wires through the bars I used kite string with a nut tied on the end and just let the nut fall down through the bars... then pulled the wires straight through. Worked beautifully.
The one thing I learned (although most setups aren't like this) is that for my risers, the bolts that tighten the bars are on the bottom to give a clean look up top. When the risers are installed, they sat so close to the top clamp I couldn't get an allen wrench in there to tighten the bars down. So I needed to partially install/tighten the bars to the clamps prior to mounting both on the bike then I grinded an allen wrench down to fully tighten. it was a pain, but like I said I haven't seen many cases like this. most risers secure the bars with bolts from the top.
Old Feb 24, 2015 | 06:52 PM
Kraken's Avatar
Kraken
I used chain small enough to go through to do the initial threading then attached a pull wire to get the wires through. Fairly simple process.
lithod02
Dec 15, 2017 07:05 PM
bekkermatt1989
May 26, 2016 08:11 AM
Rangerdan
May 1, 2010 12:23 PM
reds2harleys
Aug 22, 2009 11:23 AM
gigiflip
EVO
Mar 28, 2008 10:59 AM
