2014 FXDB Loss of Power/Hesitation
Old Feb 24, 2015 | 09:52 PM
speedkills66's Avatar
speedkills66
Exclamation 2014 FXDB Loss of Power/Hesitation
2014 FXDB - 4000 miles.
Earlier today I was on the freeway doing 80-ish when there was a sudden loss of power - it lasted only a couple of seconds. The deceleration was similar to totally releasing the throttle.
I re-accelerated and a few seconds later it happened again.
That time it reminded of the feeling when you bump against the rev limiter - but I was nowhere the rev limit - I glanced down and was a bit over 3000rpm at that moment.
It also felt similar to running out of gas.
The bike did not shut off or die - just no power as if I released the throttle.
I moved over to the far right lane in case I lost all power and maintained 60-65 mph the rest of the way home but never felt it again.
I have a full tank of gas. Plugs are clean. Mods as listed in my signature.
Any ideas where to look first??
Spark plug wires? Coil harness? Crap in fuel tank??
I run a Powervision but do not have it hooked up all the time.
I think if I attach it to the bike I should be able to see if theres a trouble code.
I'm going to try that next.
What else can I check?
I'll be nervous riding now waiting for the bike to lose power or die if I don't sort this out....
Old Feb 24, 2015 | 11:02 PM
moosehunter22's Avatar
moosehunter22
Maybe you got bad gas or something? I don't know..but I can bet you will get a lot of answers here shortly.
Old Feb 25, 2015 | 08:23 AM
maddghost's Avatar
maddghost
bad gas is my thought too or loose battery connection.
Old Feb 25, 2015 | 08:37 AM
Mr Bentwrench's Avatar
Mr Bentwrench
I'd run some Sea Foam through it first. If it ain't gas, its electric. Sea Foam is quick, cheap and easy.
Old Feb 25, 2015 | 09:06 AM
joe40x's Avatar
joe40x
Check the wiring on the coil relocation.
Old Feb 25, 2015 | 10:14 AM
speedkills66
I will check the battery connections.
The coil relocation has been on for over a year but I'll check those connections as well.
I did have my plugs out recently maybe I damaged a plug wire? I'll change those.
And I guess seafoam couldn't hurt, but I really suspect electrical or ignition is the culprit here.
Thanks for all your responses.
Old Feb 25, 2015 | 10:27 AM
Suede Blue Man's Avatar
Suede Blue Man
Did you check for codes just using the tripmeter button (without the PV)?
If you haven't that's a good quick check to see what it says.
Old Feb 25, 2015 | 11:55 AM
Mascman's Avatar
Mascman
I would check plug wires since you said you had them off.
Battery connections at frame and battery. My brother had one of his come loose and it acted like you describe.
I don't know if you have ever checked your fuses, but they get corroded...pull them and clean and put a little dielectric grease on them.
almostakeeper
Dec 29, 2018 04:12 PM
ARech09
Jun 30, 2013 06:53 PM
ultraherbie
Sep 27, 2011 01:35 AM
GypsyRoseTattoo
Exhaust System Topics
Jun 26, 2009 09:36 AM
qwest
Jun 17, 2009 09:17 PM
