ABS or Not
Old Mar 6, 2015 | 02:05 AM
zamiam's Avatar
zamiam
Originally Posted by JustOneDean
You're full of ****. It does not disable your brakes, it pulses them roughly seven times a second, depending on the exact model and system. It will increase your stopping distance if you have spent the many, many hours to master threshold braking on your motorcycle and are stopping on a surface that you know is clean and dry, like a racetrack. If you haven't done that, ABS will stop you faster. And even if you have, one spot of oil and your wheel's locked up.
The idea that a locked wheel will stop you faster than a rolling one is horseshit. You're dealing with two types of friction, static and kinetic. When a tire rolls, rather than slides, you're dealing with static friction between the tire and the asphalt. If it's sliding, you're dealing with kinetic friction. Static friction will make the tire slow down faster. Physics 101?
OP, ABS isn't necessary, but it's good peace of mind. As long as you know how to brake without it, so you don't rely on it, you'll be fine. In a panic situation, it's one less thing to worry about.
You're dead right he's full of ****. After having done advanced driving course unless you're a pro with a race car an ABS equipped vehicle will stop quicker AND it allows you to steer around an obstacle instead of sliding into. ABS for me ALL the time.
Old Mar 6, 2015 | 02:29 AM
AlwaysHD's Avatar
AlwaysHD
Definitely with ABS.
I could care less if I have to pay more to get new handlebars.
Means nothing compared to the amazing amount of breaking you get.
Old Mar 6, 2015 | 09:29 AM
Tufel's Avatar
Tufel
Originally Posted by LunaticFringe
if it pulses your brakes that means it's disabling them, which increases stopping distance. Static friction is greater than kinetic, therefore a locked up wheel does produce more friction.. again reducing stopping distance,, that's why the wheel locks up when you hit the brakes hard, because it's producing the maximum braking force possible, which ABS prevents from happening. Your statements are totally ignorant & inaccurate, btw I do have a mechanical engineering degree. I aint that smart, but I know basic physics.
abs does not improve stopping distance, it does the opposite in order to improve vehicle control. these arguments than abs does not increase stopping distance just don't add up, it's impossible,, it's all marketing BS to sale you that $700 option and higher insurance & parts when your in a rear end accident.
I don't think I've ever seen a post that was this completely incorrect. Congratulations!!!!
Old Mar 6, 2015 | 09:33 AM
r0de_runr's Avatar
r0de_runr
A locked up tire is producing heat which melts the tire which lubricates the friction zone which increases stopping distances.
A locked up front brake and you fall down because you have lost the gyroscope.
A locked up rear brake and you lowside because you are instinctively leaning away from the threat. Unless you let off the brake in the lowside and suddenly learn physics 102, the high side.
Old Mar 6, 2015 | 09:42 AM
BigDogIdaho's Avatar
BigDogIdaho
As was said before ABS increases an EXPERT'S stopping distance but decreases a non expert's (which is most of us) stopping distance. LF if you fall in the first category then you won't be in accidents so.....
The part where you say it causes higher insurance premiums.....? Every insurance company I have ever used gives you a deduction for safety features such as this. The more safety features you have the cheaper my insurance is. Since you get in so many accidents that might be why your premiums are so high....but I don't have a physics degree so what would I know.....
Old Mar 6, 2015 | 11:14 AM
Suede Blue Man's Avatar
Suede Blue Man
Originally Posted by golferguy
...What are your thoughts? Thanks for your insight.
Bob
Greetings Bob,
Bob, you're in luck! As fate would have it, today I have been appointed "Swami" Blue Man (you can call me Swami today) and as such am here to answer your question of ABS or not.
Now, I do admit I am only a 2%'er but meaning that only 1% of riders are better than me I do humbly say I am still qualified to render final and all binding judgement on this answer. And although I respect everyone's right to state what they like either not knowing or actually believing wrongly, this is not a debate.
ABS is one of the smartest inventions on bikes for safety and it will greatly increase your odds of surviving out on the roads.
Don't be like the other Rob Lowe, get ABS.
I don't have it on this bike, I was impatient and wanted a charcoal pearl one.
Keep in mind though, I'm a 2%'er, in my own mind and ride accordingly.
The has spoken.
Old Mar 6, 2015 | 11:36 AM
golferguy's Avatar
golferguy
Oh Swami. Thanks for imparting your fine wisdom on this discussion topic!
And to the other responders thanks as well. I am very educated now!
Bob
Greetings Bob,
The has spoken.
Old Mar 6, 2015 | 12:35 PM
JustOneDean's Avatar
JustOneDean
Bolded relevant sentence. That's my point. You've got the two forces reversed. A rolling wheel works against static friction, while a sliding wheel works against kinetic friction. Maximum braking force will lock the wheel, resulting in sub-optimal braking effectiveness. Maximum braking effectiveness is at threshold braking, where any more braking power or any less traction will lock the wheel. Maintaining that point will slow you down the fastest. The problem is, you have to know a bike very, very, very well to achieve that with any consistency, and that still doesn't account for traction. If the road gets even a tiny bit more slippery while you're at threshold braking, the wheel locks up and your stopping distance increases. ABS means you don't need to worry about that.
EDIT: If you won't accept that, let's take two cars that are exactly the same, except one has ABS and one doesn't. You drive the one without. Lock your wheels up and we'll see who stops first.
Old Mar 6, 2015 | 03:18 PM
103inches's Avatar
103inches
I would bet on the ABS equipped vehicle. I think the point being missed is that once the wheel locks, you're not stopping but rather traveling forward with a locked wheel. I've done this once or twice, and you can maintain control especially if you lock the rear wheel... but you're not stopping...you're still moving forward. ABS prevents the lock-up from occurring so you STOP sooner, in a shorter distance. If you can pump your brakes fast and consistently enough you can achieve similar results.
Old Mar 6, 2015 | 07:59 PM
JustOneDean
