Screamin Eagle Stage 4 kit for 103
FM
Just my $0.02
Screamin EagleŽ CNC Ported Factory Cylinder Heads with high-performance valve springs
Matching high-compression 10.5:1 Forged Aluminum Pistons
58mm ETC Throttle Body with high-flow injectors
SE-259E Cams
Perfect-Fit Pushrods
Screamin EagleŽ High-Performance Clutch Spring
Sprocket retention hardware and top end engine gaskets
Screamin EagleŽ Pro Super Tuner to provide EFI tuning capabiliti
I understand though you want power you can trust because HD has a reputation to uphold, but your warranty on the new kit will be three months parts only if I'm not mistaken.
You Are Making an EMOTIONAL buy! If your going to lay 4000$ out for motor work what is an extra three or four hundred $ for transportation costs?
Look at what this guy got for his 4000$ https://www.hdforums.com/forum/engin...age-4-kit.html
I have that much coming out of my 107 kit from fuel moto.
Besides a 58 mm throttle body won't be delivering anywhere near it's potential you can't funnel extra hay down a horse's mouth and expect it to run faster!
SE super tuner is a good product but must be tuned by harley and you don't get to play with it it stays in the box until you re-dyno the bike some day, so you have another 560$ just sitting there.
Spend some time finding a good performance shop they are all over the place in Ontario, get a budget trailer I think it costs about 30$ for a day and drive your bike out to that shop on your day off. By the time they put it together for you you can have someone drive you there and then ride it home! The shop will stand behind their work too ya know!
Fuelmoto is too far away from me, and to my knowledge there's no indy's around me..... I live in the middle of nowhere
