New stuff on the way
Old Mar 15, 2015 | 06:55 AM
Bbrownsb14's Avatar
Bbrownsb14
After hooking up my power vision and running the wire up the back bone under the tank I figured I'd go ahead and install the clamps and headlight bracket for my ness fairing, with lining it up and by following the directions when I put the shield on I'm going to have to spread it out about half a inch on both sides to bolt the screen on. I was wondering if any one else had this experience with there s I was kinda concerned with the cheap plastic bolts that hold it on?
Old Mar 16, 2015 | 08:44 PM
Bbrownsb14's Avatar
Bbrownsb14
Default Got em on
So got the other set off bars in the dent in the throttle side is supposed to be there I'll be damned well ended up unbolting the tank to have more access to the clips pulled the grommets off in the frame got the connecters pulled out had hell fishing the wires threw the bars had to hand fill the holes bigger the connector s wouldn't go I ended up pullin off the small connecter that goes to the throttle side I'm goin to hopefully get one in the morning or tie somethin else to solder it if the dealer ain't got one what does the little wire go to the starter? I need to buy a service manual think ill break down and order one tomorrow
Old Mar 17, 2015 | 05:08 AM
Bbrownsb14's Avatar
Bbrownsb14
How do I post pics
Kustrud
Mar 18, 2014 02:02 PM
Scottyrr
Feb 10, 2013 08:13 PM
Col.Squirt
Feb 11, 2011 04:12 PM
jojo2dog
Jan 22, 2011 11:01 PM
bailey40
Jan 19, 2009 05:51 PM
