cheap Clutch Pull reducer Kit
Old Mar 8, 2015 | 09:08 PM
LunaticFringe's Avatar
LunaticFringe
Default cheap Clutch Pull reducer Kit
do these work?
http://www.ebay.com/itm/EASY-PULL-CL...baa35e&vxp=mtr
the harley one is only $50 but it also includes a different clutch spring so then the whole clutch has to be disassembled. I'm sure it would work better but I'm just looking for a little better clutch feel..
thanks
Old Mar 9, 2015 | 12:49 AM
128auto's Avatar
128auto
Similar to burly easy boy, do a search. It works great!
Originally Posted by LunaticFringe
do these work?
thanks
Old Mar 9, 2015 | 07:25 AM
jmb79's Avatar
jmb79
Burly's version only costs $35, is easy to install, and really works well.
Old Mar 9, 2015 | 07:28 AM
jackafrica's Avatar
jackafrica
+1 on the Burly Easy Boy Lite.
Easy to fit, no pain.
Works a treat with a stock clutch.
Old Mar 9, 2015 | 07:37 AM
Lude-a-tick's Avatar
Lude-a-tick
Agree with the Burly Easy Pull, easy to install and works as advertised.
Old Mar 9, 2015 | 08:32 AM
maddghost's Avatar
maddghost
A clutch diaphram spring is about 30$ on it's own, the math seems easy. Do you need a new diaphram spring and what strength does the new spring carry. Most people install a stronger spring to stop their higher torque engines from making the clutch slip out on heavy acceleration making their clutch harder to pull and hold in during traffic or at traffic lights. So if you haven't made big engine upgrades then just the 20$ variety is all you need.
Old Apr 3, 2015 | 10:09 AM
LunaticFringe
so those who have these installed.. Did you ever have any problems with it?
http://www.revzilla.com/motorcycle/b...twin-2000-2015
I installed one, I put locktite on the nut & bolt.
I couldn't use the spacer that came with mine, it was a piece of junk. so I've got the adjustment on the cables all most all the way out..
I also installed a new braided cable when I did this and that alone made a huge difference since my old one was in bad shape. I can pull the clutch with 1 finger now though.
Old Apr 3, 2015 | 06:17 PM
jmb79's Avatar
jmb79
I have had zero problems with the Burly Easy Boy Lite.
irydasteelhorse
Mar 4, 2017 08:34 AM
2006ultra
Apr 12, 2011 10:36 AM
Rockrspud
Apr 29, 2010 02:41 PM
tramptaxi
Nov 5, 2009 08:08 PM
Lady Deluxe
Jul 1, 2007 07:39 PM
