I just installed them on my street Bob and they push out a lot of dirty air. It looked like two little locomotives pushing out smoke. Is that normal? Was the engine too hot? I have the oil sitting at the top of full.
I just cannot see sitting at a stop light breathing that in. Anyone with experience or knowledge about this please let me know what is normal for this system.
That sounds like something is wrong. I have breather bolts on my Fat Bob and there's no smoke or dirty air that comes out of them - and so far no oil mist either.
I have them and I don't get a lot of smoke coming out of them .From time to time I see a little bit of smoke but mostly smell it because it's not being sucked back into the motor via the air cleaner
I dont have smoke coming out of mine, I do know if I fill my oil to the full mark some will get pushed out, I fill mine up about halfway on the stick and nothing comes out.
Did you mean the oil is at the full mark when hot or cold? If it's at full cold then you have a little too much. Let it go down some and see if the mist and goo disappear. I keep my oil at the halfway mark when cold and it doesn't budge till next oil change. When I used to fill it to the full mark I had to keep adding to keep it there, then it dawned on me~fill it less! If the problem persists it may mean that the drainage holes in your heads are clogged or simply not drilled out big enough.
Not sure what hole you are talking about drilling bigger but do not drill the bottom of the baffle plate with the one way out popet (butterfly) valve. It appears small but just a little oil gets in there and drains out. If you drill it bigger, it will actually allow more blow-by from the crankcase coming up through the pushrod tubes at a higher rate. The other drain hole is fairly large . I know there was a post on here a while back about the design and how the screens should be positioned to catch oil. If your motor is fairly new, it could still have more blow-by then it will have after a few 1000 miles. Remember, you will see lot less oil in filter if you drive regularly since if it sets weeks, the oil will drain down that is in plumbing. Also 70+ driving and you are going to have some on the outside with an open SE heavy breather or open breather bolts. As long as the oil level it not above full when hot, it's not too full. The oil pump pulls the oil into the motor, not gravity. However a Softail will drain a little in setting for a while but the larger return side of the pump gets rid of it in seconds.
The hole is the drain back hole (one in each head), the heads would need to come off for that job and i think the spec calls for no more than 3/32ths but don't quote me on that because I did the job with a friend back at the beginning of '13. It depends how you ride and how much oil you keep in the pan. Like I said I used to have alot more blow by when I would keep the oil topped to full. Besides the bikes are all the same and yet all different to some degree. what works for one guy may not for the next. OP's may be clogged who knows? Alot of new guys post questions and offer no info such as what year / mileage, did he buy it used, any motorwork, if the bike was sitting in some garage for years and so on.
