Bob Clutch Blues....
Old Apr 22, 2007 | 09:05 PM
tireater's Avatar
tireater
Default Bob Clutch Blues....
2000 miles with sticky tires and 100 hp and it is starting to slip...
Anyone try a Variable pressure Clutch by AIM on a BOB...?
How about afriction plateupgrade ? ANYONE?
Old Apr 22, 2007 | 11:23 PM
jonpiper's Avatar
jonpiper
Default RE: Bob Clutch Blues....
what combo does it take for you to make that 100 hp ?
Old Apr 23, 2007 | 12:27 AM
dog06bob's Avatar
dog06bob
Definitely upgrade! At least put in a stronger spring, 25 bucks for a SE spring from the stealer and about thirty for the outer primary gasket! Personally, I would go with new plates at the same time to be sure. Will cost you about 250 for everything!
Old Apr 23, 2007 | 09:35 AM
tireater's Avatar
tireater
Typical Andrews 37 gear drive build with shaved pro st. heads, 95" 10-1 comp.,Thunderheder, K & N...
When the tire is cold it will spin thru 5 gears - not everyone needs to wheelie hitting 5th on the freeway...I DO !
ANYONE TRY AN EXTRA CLUTCH PLATE KIT ON A BOB?
Old Apr 23, 2007 | 09:39 AM
tireater's Avatar
tireater
Same build on both bikes...95", 10 to 1,shaved pro st. heads - Bob is And. 37 chain drive...Elec. Glide is And. 37 gear drive......
Monkeypuncher
Apr 27, 2019 08:23 AM
apetterez
Sep 18, 2015 11:54 AM
HYPR
Nov 24, 2013 03:45 PM
Cygnus x-1
May 15, 2011 12:43 PM
MasterRye
Aug 9, 2006 01:56 AM
