Tri bar LED tail light install issues
Old Apr 3, 2015 | 07:49 PM
Wranglin4Life's Avatar
Wranglin4Life
Default Tri bar LED tail light install issues
So I swapped in the tri bar led tail light and when I turned everything on it worked except when I use the brake, it doesn't get any brighter. Neither the hand brake or foot brake. I then unplugged the tri bar and put the stocker back on and same thing. I'm not sure what's going on... Can anyone help? Thanks.
Old Apr 3, 2015 | 08:44 PM
TexasMotorcycleRider's Avatar
Did you use the additional harness?
Old Apr 3, 2015 | 08:56 PM
RANGER73's Avatar
RANGER73
Check the pin in the plug, you may have pushed it out or bent it.
Old Apr 4, 2015 | 07:37 AM
Wranglin4Life
It did not come with an additional harness. I have checked the pins and they all look strait to me.
Is a load equalizer needed?
Old Apr 4, 2015 | 08:27 PM
RANGER73's Avatar
RANGER73
If you tried the stock tail light and it still didn't work, your not getting power to the brake light.
Old Apr 5, 2015 | 12:44 PM
Mine came with a separate harness that you needed to use to make the brakes lights work. What brand light did you buy? Custom Dynamics comes with the harness I think some others you have to buy it separately.
Old Apr 12, 2015 | 09:10 PM
Wranglin4Life
Just wanted to update everyone with the situation... So upon installing the tri-bar tail light I over tightened the screw that holds the chip board in the tail light and it cracked the brake light part. It was so small I didn't even notice it, my brother was looking at it and noticed it.
So I ran over to the dealer and got a new board, it was about $27, not to bad but it was my own dumb mistake. Threw that in and everything is fixed up now. Tri bar light looks so much better! Thanks for all the advice everyone.
Old Apr 13, 2015 | 06:29 PM
RANGER73's Avatar
RANGER73
But you said you had re-installed the OEM light and it didn't work either.
"So I swapped in the tri bar led tail light and when I turned everything on it worked except when I use the brake, it doesn't get any brighter. Neither the hand brake or foot brake. I then unplugged the tri bar and put the stocker back on and same thing. I'm not sure what's going on... Can anyone help? Thanks."
Old Apr 14, 2015 | 12:26 AM
blueangel73's Avatar
blueangel73
Got pics?
Bertk
Mar 29, 2012 10:12 AM
lazy eye
Electrical/Lighting/Alarm
Feb 1, 2012 08:18 AM
Spiro Drummer
Jul 28, 2011 12:18 AM
rdown1976
Nov 23, 2009 01:08 PM
detonator
May 14, 2008 05:49 AM
