No Baffles = How much performance loss?
Old Apr 15, 2015 | 11:36 AM
Derik's Avatar
Derik
This is my review of the thunder torque inserts.
https://www.hdforums.com/forum/gener...e-inserts.html
Old Apr 15, 2015 | 01:09 PM
DK Custom - ST's Avatar
DK Custom - ST
Platinum Sponsor
Thanks for posting this Derik, i had to go take a look
Kelsey
__________________
Cristy
FREE SHIPPING - ORDERS OF $100 OR MORE - LOWER 48 STATES
www.DKCustom.com
Call: 662-252-8828
Text: 662-420-4891
http://i1088.photobucket.com/albums/i339/DKCustom/Links/Sig1-8-14_zps9d8aff35.jpg
Old Apr 15, 2015 | 07:42 PM
TinCupChalice's Avatar
TinCupChalice
This is what you're after, measure your pipe and use the DK Custom FAQ to determine what's going to fit best, a too small TTI won't give you what your're after, these are the W158's in my V&H Big Shots Staggered... and these things rock, no baffles and she sounds fantastic and runs like a raped ape
Old Apr 15, 2015 | 09:32 PM
stephenhelsel's Avatar
stephenhelsel
Originally Posted by Dave's 1stHog
I have to disagree about the "Poor performance" with a 2-2 system. If you have your bike properly tuned, I don't believe you actually notice any loss of power.
My bike runs like a raped ape AND it sounds and looks good!.......in my opinion.
I fully agree... i have short shots with big city thunder baffles on an 01 stock 88 with k&n intake and rejetted and she rips!
People i first started ridin with asked if i had motor work done.
Old Apr 16, 2015 | 01:19 AM
fxdc_9613's Avatar
fxdc_9613
I just took out the baffles from my 2-2 radius pipes and put in big city thunder monster baffles. I would highly recommend them, great sound and got a little gain in performance where i didn't even know there was a lack of. The bike pulls a lot stronger in the mid rpm range now.
Old Apr 16, 2015 | 10:26 AM
Derik's Avatar
Derik
Yeah, I need to order a set of 158's cause I ordered 118's because my Samson pipes are 1 3/4" but the end, where these have to be installed is 2 1/4". I went ahead and installed them and they seem good, I wanna try the 158's though and for $30shipped, WTH...
Old Apr 16, 2015 | 10:52 AM
TinCupChalice
Once you've got the baffle hole enlarged you can swap them easily and test out the W158's, I think you'll like them. The hardest part with some pipes, like these Big Shot Staggered is the heat shields needs to be tweaked due to how tightly they fit around the exhaust pipe and how high up on the shields they're full coverage. I used a dremel with a cutoff wheel and some files to cut a notch in the shields for the bolt to slide in so the shields could come on and off easily, drilling a hole in the heat shields and putting the bolt on the outside would have distorted the heat shields... some days it's some assembly required
Old Apr 16, 2015 | 02:19 PM
Derik's Avatar
Derik
Crazy bro I did the same thing, I hade to take a notch out of my lower heat shield to get them to install properly, it's on the inside so you can't see it anyways. Yeah, it will be a simple switch out for sure
Jagz
Nov 16, 2013 10:36 PM
07BlueScoot
Feb 9, 2010 09:34 PM
jayflo82
Jul 10, 2008 05:53 AM
drrandall1
Apr 27, 2007 06:15 PM
raven28690
Exhaust System Topics
Oct 15, 2006 12:45 AM
