No Baffles = How much performance loss?
Old Apr 7, 2015 | 06:11 PM
sawtooth_troy's Avatar
sawtooth_troy
Default No Baffles = How much performance loss?
I am picking up an '07 FXDB on Saturday. Bike has 19k miles on it. The seller took the baffles out of the Big Radius pipes for sound and tossed them.
During my search, I rode two Street Bobs both claiming Stage 1 done. The first (not the one I am buying) was a bit more torque-y, particular in the bottom of 2nd gear when getting on it. I was up to 90 mph in around 5-6 seconds (don't quote me on that but it was very fast).
The 2nd (the one I am buying) still got on it and was up to 90 quickly as well but definitely felt lagging compared to the first one and certainly compared to my hopped up Road Star. The lag was most noticeable at the bottom end of 2nd but seemed in the bottom end of all gears compared to the first bike.
If I put baffles back in those pipes (thinking Big City Thunder QQs), will I see a notable performance gain in torque? I know that when I took them out of my longshots on my roadstar, I lost almost all of my bottom end and replaced them within 5 miles.
Old Apr 7, 2015 | 06:20 PM
Greezey Rider's Avatar
Greezey Rider
You're on the right track, you're best route would be to get rid of those poor performing pipes altogether and put on a good 2-1 and have the best possible performance from your exhaust system.
I understand that some guys don't like 2-1 pipes and I'm just tossing that into the mix.
Taking baffles out of pipes pretty much always has a negative effect on performance, so you should at least put some baffles back in.
Old Apr 7, 2015 | 06:28 PM
TinCupChalice's Avatar
TinCupChalice
Greezey Rider is right on, I believe the loss you noticed is more about the pipes themselves, I put the Big Radius on an '05 and was disappointed in the performance even with the baffles in place. I installed DK Custom Thunder Torque inserts with the baffles removed and the performance was much improved but the Big Radius pipes strike me as a pretty to look at pipe, not a performance enhancer...
Old Apr 7, 2015 | 06:32 PM
sawtooth_troy
Hmmm, now you guys have me thinking....
I honestly had never really considered a 2 into 1 pipe.
The other pipes on the faster bike were ShortShots. Any ideas on how those two would compare performance -wise (Big Radius vs ShortShots)? I don't care much for the looks of the short shots and am honestly a bit tired of super loud pipes giving me a headache on long rides. I still love good sound and loud is fun on the commute, but sometimes it is too much.
Old Apr 7, 2015 | 06:41 PM
sawtooth_troy
Woah! Those Thunder Torque inserts are really inexpensive. Hard to believe the claims of that much power gain for $20. Am I missing something or did you just give me a great interim solution while I figure it out? Thanks!
Old Apr 7, 2015 | 06:46 PM
TinCupChalice
I really can't give you a comparison of the Big Radius and the Short Shots, I've never run the SS's but one thing I can add is like you I like great sounding pipes but not the obnoxious raspy loud you hear some people run, on 2 of my Wide Glides I've used V&H Big Shot Staggered pipes more for looks than anything else but I was not really a fan of the sound, I ended up using DK Custom W158 inserts and got much improved low end performance and the pipes took on a deep tone and lost the bright crack I hear in V&H pipes, they were quieter yet had a great deep thump to them. If someone is after sheer sound levels don't use the inserts but if you want a deep resonant tone with improved bottom end the inserts are hard to beat...
Old Apr 7, 2015 | 07:16 PM
Dave's 1stHog's Avatar
Dave's 1stHog
I have to disagree about the "Poor performance" with a 2-2 system. If you have your bike properly tuned, I don't believe you actually notice any loss of power.
My bike runs like a raped ape AND it sounds and looks good!.......in my opinion.
Old Apr 7, 2015 | 07:21 PM
HarleyBob52's Avatar
HarleyBob52
I removed my baffles and installed DK's Thunder Torque inserts,,, I didn't really notice much difference in performance,, definitely no loss in power,, but they sure sound a lot better...
Old Apr 7, 2015 | 07:28 PM
maddghost's Avatar
maddghost
Of the two the radius pipes are supposed to be better than the Sshortshits, and no surprise there because longer pipes almost always beat shorter pipes. I don't remember which forum member convinced me the radius pipes were good for torque because until he spoke up I hated anythin V&H related.
Thunder torque inserts are supposed to be good, they certainly can do you no harm, (it's like the guys who argue well my spark plugs make more power than those stock NGK's because they ignite the fuel better!), so I would say improvement yes but don't expect 5 horse or 5 lb/ft of torque to come spewing out for a twenty right? I do believe you will hear a difference however! And I mean that in a good good way!
Who knows what else may have been done to the bike with the SS pipes to make it feel faster, remember every bike behaves differently even if they follow each other off the line at the factory.
Old Apr 7, 2015 | 10:16 PM
jtarter's Avatar
jtarter
I went from a Samson short staggered to Vance & Hines Big Shot longs. I lost a bunch of low end in all gears. I installed DK's TTI's and got it all back! You can turn them to adjust sound and performance. Great product. I was just about to drop 350 on a tune until I installed the TTI's.
