Joker machine brake pedal cover
Old May 1, 2015 | 06:54 AM
Jfree700grizzly's Avatar
Jfree700grizzly
Default Joker machine brake pedal cover
I just got this pedal and after looking at the stock brake arm I see the rubber pad can be ripped off but is there a hole to mount this new cover on? Or do I need a whole new brake arm?
Old May 1, 2015 | 08:30 AM
TinCupChalice's Avatar
TinCupChalice
The Fat Bob uses the same 42542-06 forward brake pedal as the Wide Glide, there's a hole in the pedal under the rubber pad, centered on the pedal. You might be able to slip the rubber brake pad off but typically you've got to slice it to remove it...
Sharpie
Aug 12, 2013 11:36 AM
frogg
Dec 27, 2009 07:38 PM
eglinski
Jul 5, 2008 12:54 PM
gregm
Aug 20, 2007 07:40 AM
gregm
Aug 2, 2007 11:54 PM
