The belt to chain drive conversion thread
Old Feb 2, 2017 | 12:08 PM
  #141
roadkillvespa's Avatar
roadkillvespa
Originally Posted by cggorman
I wish I could help with sprocket/spacer selection, but my bike is way different than a 2007. I would think somebody earlier in this thread documented one, though.
No problem ,I think I have got that part of it sussed ,25 T front .500 offset,flat 55T rear and .875 spacer as per Mud's recommendations,if for some reason the spacer is too wide at least I will have the option of having it machined, as sending it back won't be practical.
Here's a couple of pictures of the belt.
Old Feb 3, 2017 | 04:47 PM
  #142
Stevos50nuts's Avatar
Stevos50nuts
My experience
2014 street bob. Zippers kit 25-53
25t up front helps with clearing the passenger peg mount no problems.
Before going chain I did a 30t front pulley and loved the gearing. It was perfect for me. I feel 25/53 is spot on
Old Feb 4, 2017 | 12:33 AM
  #143
Daddy454's Avatar
Daddy454
Not much to add,just thought I'd throw up a pic.Did this all last year before Arizona Bike Week.5,000 miles with no issues yet.
Old Feb 4, 2017 | 05:17 AM
  #144
cggorman's Avatar
cggorman
Cool Softie. I've got an open primary on my dream list, but so spendy.
Old Mar 2, 2017 | 09:36 PM
  #145
96sled's Avatar
96sled
hey lama i can really use your help.. if you can answer a few questions for me i would owe you big time! i have a 2016 street bob pretty much in the same boat you were when converting to chain drive i need a 7/8 spacer with a .500 offset got that all figured out. im running 13.5 works performance shocks my number one concern is how much rub do you get from the chain? i know bung king makes sliders but im worried about eating them up all the time just seems like a pain, everyone tells me i wont rub but looking at your pics that looks close! also im going to order the arp bolts i know there 7/16 but can you give me the exact size? im trying to do this with little to no down time. one again if you can answer my few questions it will be greatly appreciated. last question is i know your speedo was off but does it throw the tachometer off as well? thank you!!
Old Mar 2, 2017 | 09:47 PM
  #146
96sled's Avatar
96sled
Originally Posted by Lama
.875" (7/8") Vulcan Spacer arrived (FAST!) today, so its time to reassemble. Now = perfect chain alignment. This is THE spacer for a 2006+ bike using a .500" offset front PBI sprocket:
Ok, here's a little bit of an issue. The underside of the chain as it passes through the top run of the primary case comes millimeters close to rubbing a support casting of the outer to inner primary case. This is very evident as I am using a 24T front sprocket. Also having 13.5" rear shocks exaggerates the chains path towards this lug. It will without doubt rub this aluminum casing:
Old Mar 2, 2017 | 10:57 PM
  #147
cggorman's Avatar
cggorman
Stock screw:
SCREW 7/16-14 X 2-5/8 HEX CAP W/WASHER, LOCK PATCH
If you can measure the mounting flange thickness of the current belt pulley, you can subtract that dimension from 2.625 to get the thread engagement. Add the thickness of the new sprocket (.5, iirc) plus the adapter thickness (.875) to the thread engagement and you've got your answer.
The tach reads engine speed irrespective of gearing or tire diameter. It will be accurate for measuring engine speed, but not estimating the old ground speed. ie, if 2500 rpm = 65 mph in 6th with the belt, it WON'T be 2500 @ 65 with different final gearing. Either use GPS or an aftermarket speedo that can be calibrated.
Old Mar 3, 2017 | 06:34 AM
  #148
96sled's Avatar
96sled
Stock screw:
thank you sir I'm new here so it's been kind of rough getting answers from anyone .. was also hoping to find out about the chain rub issue. I'm hearing mixed opinions. I'm ordering everything and I'm just happy trying to have as little downtime as possible. If I went 25-60 instead it 24-55 would that get me more clearance ?
Old Mar 3, 2017 | 06:50 AM
  #149
cggorman's Avatar
cggorman
I'm sorry, but I can't answer the slider question. My bike is an old 5 speed and doesn't have that issue. I run without a slider. That said, the slider is on the slack side of the chain so it won't see the kind of wear that an actual tension would. It just keeps metal/metal contact from happening. I wouldn't expect much wear on it, but honestly that's just a hunch on my part.
Old Mar 3, 2017 | 07:24 AM
  #150
96sled's Avatar
96sled
thanks so much again. I would like to talk to lama but I'm new and I don't think they'll let me PM anyone yet haha 😂 is there a way to tag him? I'm bothering everyone on here already huh .. seems like a great forum though
