torque spec for three hole
Old May 17, 2015 | 06:26 AM
blueridge's Avatar
blueridge
Default torque spec for three hole
I cannot seem to find my '12 FXDB book to look up the torque spec for the three holes for fluid change and also the torque spec for the 6 screws that hold the primary (is this called the primary damn I forgot.) Someone have the spec they can post.
Old May 17, 2015 | 06:52 AM
Iceman24's Avatar
Iceman24
JMO, but don't "torque spec" these service points as this is when you run a chance to strip or damage threads/heads. When working these bolts...I go by "feel" and then you lessen the chance of starting a new " I Stripped my Fill/Derby Bolt" thread...
Old May 17, 2015 | 07:08 AM
blueridge's Avatar
blueridge
Iceman,
Yeah I do that way with my vehicles. But I did use the torque spec for my harley as if something comes lose on the road I'd be run over lol. Worse case is I was gonna go by feel but I also like to know how my feel is corresonding to the book spec.
Old May 17, 2015 | 07:13 AM
Jackie Paper's Avatar
Jackie Paper
Justfill. The bottom 3 go metal to metal since since the oil ring seals in the taper. So go up snug and bump the 3/8 ratchet with a little bump tug. The small screws in the derby cover are usually squeezing a gasket. Just use a had torix or if a 1/4 drive ratchet, put the extension between your fingers. Remember to crisscross. I go real easy on these. I recheck after a ride on those small ones and it is hot. The book is 84-108 in-lbs Bottom plugs are 14-21 ft-lbs
Old Aug 4, 2024 | 06:20 AM
whododat's Avatar
whododat
Thank you all again. Appreciate it.
hemi1300
Aug 6, 2015 07:19 AM
deuce_streetbob
May 15, 2013 08:40 AM
30glock
Dec 17, 2011 08:50 AM
Good Time Gang
Jul 22, 2010 11:01 AM
dawg
Jul 20, 2006 05:58 PM
