Stripped Bolt Help
Old May 25, 2015 | 09:28 AM
smartass12's Avatar
smartass12
if you have access to a welder build up the end (if its atleast still flush with the frame or further out) then grab that puppy with vise grips and get it out. worked for me at least 40 times or so.
Old May 25, 2015 | 10:40 AM
skinman13's Avatar
skinman13
I approach snafus like this with the idea that it will probably have to be completely reworked and try not to waste too much time with trying to get the seized bolt out. So, if it were me, I would work from the thought that I probably will have to redo the hole, and since you are already off-center with the hole in the bolt, I would first try to drill the bolt enough on the thin side of the bolt to the point where I can try to collapse it inside the hole with a punch or chisel. If you can do that, the bolt should loosen up and come right on out. The trick here is not damaging the tapped hole to the point that it will not hold a new bolt securely. If I cannot do this, I would drill the whole mess out, redrill and retap the hole and insert a helicoil. For me, the entire process is all about inserting the helicoil...if I am lucky enough to get the seized and sheared bolt out without damaging the tapped hole, then that is just a time and work saving bonus.
Good luck and let us know how it goes...
Old May 25, 2015 | 10:47 AM
Sebass's Avatar
Sebass
This.
Whatever you do, do not...I repeat do not use an EZ Out! You will just end up getting it stuck and/or broken off in the bolt then you will have more of a headache. Don't ask me how I know
Old May 25, 2015 | 01:11 PM
Uncle Larry's Avatar
Uncle Larry
Timesert is also another thread repair that is a bit more friendly to the novice
http://www.timesert.com/
Old May 29, 2016 | 12:31 PM
13FXDWG's Avatar
13FXDWG
Weld a nut to it tap with a hammer after you laid a good bead and it has cooled. Then work back and forth. I do this for broken exhaust manifold studs on Ford V8-V10s. Works on studs that are broke flush with the head or somewhat deep in the head.
Old May 29, 2016 | 09:47 PM
Fireguy88's Avatar
Fireguy88
I appreciate the post, however this is an older thread. I found a guy who took out and re tapped for almost nothing.
Buch
Dec 1, 2015 07:36 PM
paramedbiker
General Topics/Tech Tips
Jun 11, 2012 02:59 AM
SC-Longhair
Sep 20, 2011 10:50 PM
Brad2064
Jan 9, 2011 09:35 AM
bmedeiros678
Jul 16, 2009 08:04 AM
