My bad day...
Old Sep 18, 2011 | 08:52 PM
SC-Longhair's Avatar
SC-Longhair
Default My bad day...
Ever have one of those days where no matter how simple the task, you just seem to eff it up?
Since I relocated back to NJ and now have a garage I was unpacking some stuff and came across a new set of larger iso-pegs w/ stirrups I bought at one of the Rockingham, NC AHDRA events. I had totally forgotten about them. Anyway, I figure I'll take 30min and install them. My brake pedal was sticking so I figured that'd be a good time to clean and lube that as well.
The left side peg goes on without issue.
The right side....well...not so much.
I remove the bolt holding the pegs to the stanchion. No problem.
That exposes the T-40 torx bolt that holds the brake pedal assembly all together. Oooook.
Grab my t-40 socket. After a few moments, I snap the bit. Ok. I go buy another one. The bolt is just frozen. Didn't want to damage the new bit so I grab one of my EZ-outs. Drill the bolt, tap the ez-out in and try to loosen the bolt. Try one more time and all of a sudden my ez-out snaps flush with the head of the bolt. OH CRAP.
Picture of the snapped ez-out in the bolt:
I try the 'ol 'tapping the head of the bolt with a screwdriver' trick hoping to loosen it that way. Nope.
I try to drill the ez-out, out. Nope.
My bud stops by and we're brainstorming. I remove the whole bracket from the frame and he suggests drilling and tapping the bolt from the back side. Makes sense. Once you install a bolt in the backside of the stuck one, the more you tighten it, you could actually loosen the stuck one.
Drill the bolt....begin to tap it and don't ya just know I snapped the tap off in the bolt.......flush.
Oh well, I'll get it apart one way or another.
Old Sep 18, 2011 | 09:00 PM
bucket13's Avatar
bucket13
that sucks....it was a beautiful day today too! Where in jersey are you?
Old Sep 18, 2011 | 09:03 PM
SC-Longhair
Yeah it does suck but I kind of just had to laugh it off. I'm in Hawthorne.
Old Sep 18, 2011 | 09:10 PM
DTDK's Avatar
DTDK
Well, i have in the past had luck with bashing the hell out of ez outs and taps with a punch or chisel, to break them up when i have had similar issues, also you can grind that stuff if you have a small enough grinding bit to get down in to the holes you drilled.
Old Sep 18, 2011 | 09:38 PM
Austin Dave's Avatar
Austin Dave
Murphys Law at work. Onward thru the fog.
Old Sep 18, 2011 | 09:50 PM
misfitJason's Avatar
misfitJason
I hate to see a guy loosing a day of riding when he lives up north
Old Sep 18, 2011 | 09:55 PM
SC-Longhair
I've only 'lived up north' for two weeks. I wasn't going to ride today anyway. My lil girl was sick and giving my girl a really hard time so I did my best to deflect some of the stress away.
Old Sep 18, 2011 | 09:57 PM
macnab_sf's Avatar
macnab_sf
I have the same exact bolt frozen on my bike. I have stripped the torx screw out, and stopped there...
Old Sep 18, 2011 | 10:13 PM
that_guy's Avatar
that_guy
no heat or pb blaster? I soak my bolts in thsat almost all the time before working on stuff.
Old Sep 18, 2011 | 10:19 PM
SC-Longhair
Based on location of the bolt, I don't feel heat is an option. Concerned about damaging the painted parts. I didn't try using pb blaster (or a similar product) before I started. I just didn't expect to end up where I am when I started.
