SMOG CANISTER
Old Apr 26, 2007 | 08:16 PM
07bobber's Avatar
07bobber
Default SMOG CANISTER
ANY PICS OF HOW TO REMOVE THE DAMN THING
Old Apr 26, 2007 | 08:30 PM
nkauf21's Avatar
nkauf21
Default RE: SMOG CANISTER
Cant get you pics, but here is what I did. The big hose that i believe is on the a/c side of the bike, just yank it out. You don't need it. On the other side, you have a gas vent hose and another hose that i think is a breather hose. I unplugged both hoses and cut them down a little bit. Then i plugged the breather hose with a small screw and left the gas hose open. Then i just zip tied them to the inner part of the frame with small black zip ties so you dont see them. After that all that is left to do is pull the canister off. I just yanked really hard and it came out of the mount. Then just unbolt the mount, but be careful because it is also the motor mount so take it off one bolt at a time or your motor will drop a few inches and you will have to jack it back into place. (im not talking from experience though!). Last but not least, peal off the emissions sticker and you are all done.
Noride's Avatar
Noride
I don't have any pics of the removal. I left the hose that run down from under tank by shoving them behind the down tubes. The can itself is held by a couple of bolts. the hardest part of all this is actually getting down on the floor and getting a little dirty.
Old Apr 26, 2007 | 09:25 PM
WS6 Formula's Avatar
WS6 Formula
Read post #6 https://www.hdforums.com/m_326157/tm.htm
deepsea
Ironhead
Oct 22, 2015 07:49 AM
Superchick
Engine Mechanical Topics
Sep 18, 2014 08:42 AM
berndog
Shovelhead
Jun 20, 2011 07:49 AM
DeneFXDWG
Aug 19, 2010 08:40 PM
Hardly Dangerous
Jul 24, 2008 01:36 PM
