Wheel Help
Old Jun 11, 2015 | 10:50 AM
theranch's Avatar
theranch
Wow, so it seems like a lot more than just getting a meachined spacer. I hate to do it, but it looks like I will need to sell them and get 00 to 06 rims, because I'm sure a meachine shop would not be cheap for all this work.
Old Jun 11, 2015 | 11:09 AM
multihdrdr's Avatar
multihdrdr
Stick with the 2000-2007 3/4" or 1" wheels...You'll put your 3/4"ID bearings in either one and it will be a direct swap.
Old Jun 11, 2015 | 12:51 PM
blueangel73's Avatar
blueangel73
Two machined axle spacers with an I.D. made to fit around the 3/4" axle and O.D. made to fit the tappered bearings, then cut to the right length to center the wheel between the forks and you should be good for rolling (I would think anyways). An offset spacer for the brake disk to relocate it to the center of the caliper and you should be good for stopping. You might be able to pick up everything you need on JPCyles, Drag Specialties or maybe the guys at Hog Pro might be able to help or point you in the right direction.
http://www.jpcycles.com/motorcycle-p...&Ntk=All&Nao=0
Old Jun 12, 2015 | 07:38 AM
blueangel73
You can also find spacers at Paughco.com
StreetBrider
Wheels/Tires
29
Feb 18, 2015 01:45 PM
badger3x
May 18, 2014 09:13 PM
sparks427
Wheels/Tires
Jun 2, 2013 08:53 AM
shawn riley
Feb 27, 2013 03:51 AM
hogster1961
Dec 30, 2009 06:11 PM
