Not baffling... Really
I've found the same, DK Custom W158 TTI's in V&H Big Shots Staggered with baffles removed, the sound is much deeper than stock, that bright rasp is gone and the low end and mid range is back; if you want to remove the stock baffles this is the only way to go!
Thunder Torques are an inexpensive solution to getting your low and mid range torque back but, i do understand if you change exhaust frequently. It is always good to know you have other options
Cristy
FREE SHIPPING - ORDERS OF $100 OR MORE - LOWER 48 STATES
www.DKCustom.com
Call: 662-252-8828
Text: 662-420-4891
The TTI's are not like stock baffles. They are installed similarly, but the outcome is a huge difference. The type of material, shape, size, thickness, & surface coatings all make a difference in how well the Thunder Torque works at increasing exhaust gas velocity.
The TTI's obviously have their genesis in the simple lollipop concept. But they are quite a bit more, especially the W series.
Technically exhaust systems cannot increase or decrease an engines power. However, and this is a BIG however, exhausts systems can have a profound effect on increasing or decreasing engine pumping loss.
The Thunder Torque Inserts have a proprietary shape that is much better at increasing exhaust gas velocity, thereby reducing reversion, which reduces engine pumping losses, and increasing inertial scavenging. Net result is a significant increase in power & torque in the low and mid range Without sacrificing any top end.
Kelsey
I swap out my pipes after every ride over 20 miles.
