Help with pcv map for 2007 fxdb
Old Jun 18, 2015 | 06:52 PM
vsick's Avatar
vsick
Default Help with pcv map for 2007 fxdb
hey guys, Looking for some help with a canned MAP for a PCV for a 2007 Dyna Street Bob. eventually going to a 107 kit from fuel moto. but in the mean time just need a "canned" map for this setup. Power commander website has doesn't have my setup for dyna models. I don't know if I can use a softail map that has the same setup? because there site does have a map for a softail with this setup.... using a different map from there site currently but it doesn't run the best.
2007 FXDB
Stock ecm
96ci
screaming eagle intake
vance and hines 2 to 1 big radius
powercommander 5
Old Jun 18, 2015 | 11:16 PM
dirtdobber's Avatar
dirtdobber
Why not just save the present map and try the new map. If it isn't good change it back.
I bet it is a better map, just saying.
Old Jun 18, 2015 | 11:38 PM
vsick's Avatar
vsick
When I bought the PCV the base map was for completely stock, runs way to hot on that map and with the map they gave me for a different exhaust system (fatcat2to1) it's running all over the map. Over fueling, rough hot starts and so on... made some adjustments but I think the map is to far out to base off of.
Old Jun 19, 2015 | 12:04 AM
JohnMn's Avatar
JohnMn
The map doesn't care about suspension,, it's all about the air movement,,
aka; Air Cleaner and Exhaust system components.
Use the map for the engine size, air and pipes.
Old Jun 19, 2015 | 12:17 AM
jjminch's Avatar
jjminch
I just loaded a map onto my bike. It has the SE Air cleaner and the V&H 2 into 1 big radius on it. The power commander website had a map for that application for my PCIII with the O2 sensor bypass. I don't know if it will work for a PCV setup though.
Previous owner had a different map for a different exhaust. This one seems to run much better.
Old Jun 19, 2015 | 04:41 PM
vsick's Avatar
vsick
Fuel moto just sent me a map. Runs awesome. Those guys always come through. Thanks fuel moto
Old Jun 22, 2015 | 12:32 AM
kcblaze's Avatar
kcblaze
Default PCV MAp
Fuel Moto is the only place I go for controllers and maps. Those guys rock at customer support.
Old Jun 22, 2015 | 11:06 AM
vsick's Avatar
vsick
yeah they came through fast, and i cant believe the difference in how it runs with the map they sent. Looking forward to installing a new cam through them!
JZFloatingkent
The Dyno Room
May 16, 2017 12:50 AM
dmpjr
May 21, 2013 10:17 PM
jimski
Aug 28, 2010 10:15 AM
flhtupser
Apr 28, 2009 10:01 PM
Mr5150
May 6, 2007 04:20 PM
