Yet another problem
Old Jun 20, 2015 | 01:28 PM
thewoozel666's Avatar
thewoozel666
Default Yet another problem
Ok, I was fiddling around with my bike the other day trying to fix my charging issues...that problem is fixed, but I noticed today while riding that my right blinkers don't work. They were working fine before. Not only do the blinkers not work but the actual right blinker light on the speedometer doesn't blink either...Where do I start? What should I check? Any info would be great. Just so you know I do actually plan on buying a service manual soon so hopefully I can minimize my desperate pleas for help...thank you for any help!
Old Jun 27, 2015 | 01:23 PM
jmpancoast's Avatar
jmpancoast
What did your charging issue turn out to be? Have you checked your fuses as you may have blown one from previous repair? Do you have internally wired bars where you might have a short? Any skinned wires under your rear fender? Unplug TSM/TSSM and check connector for water or corrosion. Just throwing some things at you to consider.
Ginkomax
Nov 8, 2018 08:31 PM
The Nev
May 8, 2012 09:04 AM
Booey424
Mar 28, 2012 04:30 PM
nthanker
Oct 30, 2006 01:29 PM
vek74
Apr 8, 2006 01:39 AM
