15A accessory fuse keep browing up
Old Nov 8, 2018 | 06:44 PM
Ginkomax's Avatar
Ginkomax
1st Gear
Default 15A accessory fuse keep browing up
This is first time post . I have 2010 dyna street bob. Just 2 weeks ago, speed meter, turn signal, time and milage didn't work. Bike start and run and head light is on. I checked fuse when I got home and accessory fuse was bad so I replaced spare. Next day, I turned ignition key on and everything comes up as normal but it's gone when engine started so I checked fuse that was brew up again. I replaced another spare one and then everything got back fine. Today it happened again. I replaced fuse and this time speed meter work but no turn signals doesn't work. I checked Battery cable and they are tight. I checked code and showed b1121. Is it relates the my fuse problem? or different problem? Need help to figure out
Old Nov 8, 2018 | 07:33 PM
crusader1xxx's Avatar
crusader1xxx
Ok, first....Did you do anything electrical related prior to this happening? Change lights? Bars? Anything? If not have a look at your wiring harness under the rear fender, above the rear tire, known for rubbing on the electrical wires there...
you have a short somewhere and need and need to trace it back. If the wires under the fender are good, then start at the battery and work out from there....
Old Nov 8, 2018 | 07:38 PM
TriGeezer's Avatar
TriGeezer
What is a fuse that “brew” up? Maybe it hates that nasty Oregon IPA crap.
Get a factory service manual, and diagnose. If you can’t do that take it to someone that knows a “Browing” and “brew” fuse from a rock in the ground.
ok...I’ll be nice. Take it to a professional.
Old Nov 8, 2018 | 08:31 PM
Ginkomax's Avatar
Ginkomax
1st Gear
I haven't done anything since I got the bike 5years ago. I'll check the wiring harness. This is first time I'mhaving issue with the bike since I got. Thanks for replying
Bowhunter8607
Jun 7, 2015 06:44 PM
gez45
Mar 15, 2015 10:43 AM
bunotz
Apr 13, 2014 03:30 PM
Schaub85
Jun 30, 2011 12:20 AM
danl
Jun 23, 2011 11:53 AM
