Thoughts.. Enforcer wheels
Old Jun 28, 2015 | 10:19 PM
gartec81's Avatar
gartec81
Default Thoughts.. Enforcer wheels
So front enforcer rim is dual disc. Vrod/lowrider floating rotor
What would need to happen to an enforcer front wheel to fit it to a 15 street bob
Bearing/axel change. Machine the wheel. Custom spacer?
What would be needed to fit those wheels to a mid glide 49mm dyna
Old Jun 28, 2015 | 10:42 PM
Lama's Avatar
Lama
The Enforcer wheel does not use the Vrod/Dyna/FXDL brake rotor. It looks similar but it's not the same rotor.
I believe the rotor diameter is also incorrect for Dyna calipers, it is Touring Brembo spec.
The spacing of Rotor to Rotor (left to right) is setup for Touring 41/49mm WIDE GLIDE. Not mid glide.
Wheel is for wide glide, although that could be cured with spacers.
You'd have to adapt calipers to work.
harley9701
Wheels/Tires
Feb 20, 2015 09:46 AM
Mark Denmarsh
Wheels/Tires
Apr 2, 2013 04:11 PM
nexeradg
Jan 6, 2012 01:25 PM
jjor01
May 28, 2010 07:40 AM
jarhead45
Oct 4, 2009 03:51 PM
