Fuel tank issues 2008 fxdf
Old Jul 5, 2015 | 08:37 PM
cerati666's Avatar
cerati666
Default Fuel tank issues 2008 fxdf
I took the fuel pump off my bike to replace the filter and the fuel sock at the bottom of the pump. When I put humpty dumpty back together, it will start, but it will stall (as if out of gas) after about 10 seconds or so. Any ideas/help? I'm at a loss... Thanks in advance
Old Jul 5, 2015 | 09:44 PM
Ironcleveland's Avatar
Ironcleveland
Not much else you can do but take it bake apart and see what got missed.
Old Jul 5, 2015 | 10:11 PM
DonN's Avatar
DonN
Did you replace the fuel line at the same time? Could have a pinhole leak and gotten worse when you removed the innards, but probably wouldnt start at all. If you do go in, would go ahead and change the fuel line for peace of mind.
Old Jul 11, 2015 | 01:29 PM
cerati666's Avatar
cerati666
I replaced the regulator and that fixed it. Thanks for the replies.
mortensenbt
May 7, 2019 08:24 AM
toxic
Apr 8, 2015 03:27 PM
priceamp
May 19, 2013 04:56 PM
Hwnorth
May 22, 2012 07:10 AM
o3softtail
Jun 23, 2009 12:57 PM
