Funny noise from front brakes
Old Jul 7, 2015 | 04:29 PM
on3wego's Avatar
on3wego
Default Funny noise from front brakes
I've got a 2015 wide glide with the ABS. I took it to the shop the other day because every time I hit the front brakes, it makes a noise like that sounds like air bubbles escaping a hose. It does it regardless of whether I use light or heavy pressure. Its fairly loud. Loud enough that I hear it when I'm doing anything over 10 mph. Granted I do wear a half helmet, so I hear everything.
The tech assures me that its normal. He said it was the sound being made by floating brake pads. This is my first bike, so I wasn't sure if they all make noise when using the front brakes or should I pursue it further and take it to a different shop.
Old Jul 7, 2015 | 04:32 PM
Greezey Rider's Avatar
Greezey Rider
What you're probably hearing is the sound of the pads passing over the drilled rotors....Normal.
Old Jul 7, 2015 | 04:34 PM
freebaggin's Avatar
freebaggin
I havent heard your bike but It's probably the freshly cut slots in the rotors, if the bike is new with low miles, It's normal and once they wear in a bit the noise will be much quieter and you won't hear it anymore. Slotted rotors always make a whirling noise when new.
Old Jul 7, 2015 | 05:28 PM
bl_dg's Avatar
bl_dg
Normal. Hard to describe - mine sounds like a steady stream of small marbles hitting a board. If it's not the floating disc, it's from the holes in the disc. But I think it's more from the floating portion.
Old Jul 8, 2015 | 07:34 AM
on3wego's Avatar
on3wego
Thanks for all the replies. That definitely makes more sense. Now I won't go back and look like a tard.
Old Jul 8, 2015 | 07:42 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Whenever I put new pads to the rotors I use a file and bevel the leading edge of the pads, this tends to negate some of that noise.
Old Jul 9, 2015 | 09:42 AM
Peej's Avatar
Peej
All the new ones go zzzzzzzzz on the front brake. I was next to a guy the other day on his newer SB and we came to the stop and zzzzzzzzzz from his too.
civilbob
Sep 11, 2012 06:26 PM
sstlcm08
Apr 29, 2012 03:07 PM
Gonzy
Feb 6, 2011 08:12 PM
sulkaman
Jun 24, 2007 02:22 PM
05UltraClassic
May 19, 2006 12:23 PM
