extremely high idle when warm
Old Jul 13, 2015 | 07:13 PM
gbuss5's Avatar
gbuss5
1st Gear
Default extremely high idle when warm
I have a 2012 Switchback completely stock with 23K+ miles on it. The bike starts fine, normal high idle (1.7k) at first, then drops down to around 1.1k or 1.2k. My normal idle is around 950 to 1k. Once I start to ride and come to a stop the idle just hangs around 1.2 to 1.3k. On hot days it my hang around 1.4k or 1.5k. It never drops back to normal no matter how long I wait. I have been back to the dealer for them to check it out, but they can't seem to find what is wrong. I did get a code P0507, which is idle to high (I already figured that out without the check engine light coming on). They put in a new IAC (which they said the flow chart said to do) and checked all connections, checked for intake leaks and cleaned the IAC port. They put a scanner on it, all sensors checked out good. I still get the trouble code when idle goes above 1.3k, but never any other codes. Help
Old Jul 14, 2015 | 07:02 AM
charger426's Avatar
charger426
uhhh how did you get a big twin to go 17,000 RPM (17k) at all with out blowing up?
Old Jul 14, 2015 | 09:42 AM
gbuss5's Avatar
gbuss5
1st Gear
put a . between the 1 and the second number. Sorry about the mistake.
dwatkins
EVO
20
Jan 27, 2021 05:53 AM
madchemist24
May 28, 2011 06:40 PM
EVOrider
Aug 25, 2009 04:23 PM
Raiderse
Jul 12, 2008 09:26 AM
Chief101
Oct 15, 2006 03:41 PM
